Old 03-20-2009, 01:56 PM   #1
randibou
randibou is on a distinguished road
randibou's Avatar
Default High Idle AND now High RPMs 1995 SC2
My 1995 SC2 has a high idle anyway, however, lately, the RPMs run around 2500 at 60MPH and at 3000+ at 70+. It's like the RPM gauge moves along with the speedometer almost at an even rate. I have not checked it above 73MPH. What should the RPMs be at various speeds, anyone know?
I thought that for the year I've been driving the vehicle, the RPM would gradually increase as I accelerated and then when the car shifted it would decrease, but now it stays high until of course I decrease my speed.
Can someone direct me on how to troubleshoot this issue please? I had a mechanic look at the high idle problem some time ago and I'm sure he tried all the usual stuff, but he did admit to not knowing much about Saturns. I would think that this high idle and high RPM problem would be related. Another friend thinks that it could be a vaccuum leak.
I'm sure this is unrelated, but, I did add some Lucas to my last oil change to possibly fix a leak or whatever is causing me to lose a quart of oil after a couple of months. The car sat for about 2 weeks and when I drove it after that, that's when I started noticing the high RPM problem.
Anyway, any help you can provide would be appreciated. On another note, I also have the reverse jerk issue as well. I know, typical Saturn issues I guess. I hope to resolve that one soon too.
Add to randibou's Reputation
Rate the quality of this post and help randibou reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
randibou is offline   Reply With Quote
Old 03-20-2009, 02:06 PM   #2
OnDaGround
OnDaGround's Avatar
1993 SC2
Default Re: High Idle AND now High RPMs 1995 SC2
DOHC, its not likely to be a vacuum leak. 3000 rpms at 70+ sounds about right. Is the car an auto or manual? Maybe this will help. It has in there how to find a vacuum leak as well if you really want to check for it. But these are the main causes.
http://www.saturnfans.com/forums/sho...d.php?t=132844
Saturnless...
Old 03-20-2009, 05:38 PM   #3
DonP
Welcome.
Your first post - a new member. Check and as necessary replace your ECTS, it can cause high idle, and a number of other driveability issues. Check the fIrst few sticky threads in tHe How-to Library forum. Once you know the ECTS is good, you can move on to other diagnostics.
On my '95 SL2 5 speed in 5th, 2000 RPM ~ 50 MPH, 3000 RPM ~ 75 MPH, and so on,i.e., divide the RPM by 40 to get the MPH.
Add to DonP's Reputation
Old 03-20-2009, 05:52 PM   #4
Fox Slaughter
Fox Slaughter is on a distinguished road
Fox Slaughter's Avatar
So what you are saying on a MP3 transmission in 5th gear if you were at 6K rpms you would be going 150 mph?
If you had a built motor and a stand alone system and crank balanced to 9K you could go 225 mph in a Saturn?
I'll be sitting at my desk
With a gun in my hand, wearing a bulletproof vest singing
"My, my, my, how the time does fly, when you know you're going to die
By the end of the night."
Add to Fox Slaughter's Reputation
Rate the quality of this post and help Fox Slaughter reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Fox Slaughter is offline   Reply With Quote
96 SC2 High Idle shermanator S-Series General 21 09-24-2008 06:36 PM
high idle on a 01 SC2 Cortana S-Series General 6 10-29-2006 11:07 AM
High idle on 99 SC2?? SoldMyVW4anSC2 S-Series Tech 4 12-02-2005 08:27 PM
sc2 with a high idle Mean Green SC2 S-Series General 4 11-14-2004 04:54 AM
93 Sc2 High Idle? e-big S-Series Tech 9 10-10-2003 04:07 PM
