Old 02-28-2009, 03:53 PM   #1
wolffboy
wolffboy is on a distinguished road
Default 2001 SL2 DOHC Misfire
Suddenly started misfiring last week, threw P0172 & P0341. Replaced spark plugs & wires - no improvement. SES was solid, started blinking sporadically yesterday. Number 3 splug had oil on it (OUTSIDE the cyl) all plugs were dry on chamber side.
Should I spend $110 for a new coil when it may be a burnt valve or timing chain issue?
Any advice?
TIA
Add to wolffboy's Reputation
Rate the quality of this post and help wolffboy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
wolffboy is offline   Reply With Quote
Old 02-28-2009, 04:09 PM   #2
Default Re: 2001 SL2 DOHC Misfire
Oil on the outside of the plug(s) is just an indication of the cam cover gasket leaking oil into the plug well(s), that's all. Whether it aggravates a misfiring condition is open to interpretation as all you need to do to put aside fears of misfiring from oil shorting the high voltage spark is soaking up the oil with absorbent tissues/towels/turkey baster, etc. to remove any doubt. Either the misfiring will go away immediately or remain. You still need to perform a compression test as suggested in your other posts. Or simply remove the plugs for another quick examination in case one broke while installing them. Some mishandled their plugs and went through a whole slew of posts troubleshooting everything and anything until removing a plug to find one broken!?
VCX NANO
Old 03-01-2009, 04:51 PM   #3
wolffboy
Did compression test, and the head gasket is blow between 3 & 4
Wont know valve condition until the heads come off tomorrow.
News at 11
2001 LW300 misfire round 2 frankenkat L-Series Tech 0 09-30-2009 05:17 PM
Swapped a 2001 SC1 DOHC engine with a 2000 SL2 DOHC now have transmission issues knukklhead S-Series Tech 18 04-13-2009 07:48 PM
'96 sc2 dohc w/ ses light=#2 misfire mamalujo2003 S-Series Tech 4 06-22-2008 04:37 AM
Engine Swap - 2000 SL2 DOHC into a 2001 SC2 need connector harness hookups kim_lombard S-Series Tech 6 08-28-2007 11:42 PM
2001 SC1 - Misfire - P0302 yiimmy S-Series Tech 4 02-21-2007 08:12 PM
