Old 02-28-2009, 02:25 AM   #1
wolfehunter
wolfehunter is on a distinguished road
Default 98 SL2 Shifter Linkage?
Pulled in the driveway tonight, put it in reverse (5 speed) and I think I felt my linkage unhook. Transmission is stuck in Reverse and the shifter moves freely front and back without depressing the clutch but no side to side movement. Is this an easy fix and can someone walk me through it? All advice welcome. thanks, Scott
Add to wolfehunter's Reputation
Rate the quality of this post and help wolfehunter reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
wolfehunter is offline   Reply With Quote
Old 02-28-2009, 02:53 AM   #2
wolfehunter
Default Re: 98 SL2 Shifter Linkage?
Just got done doing a search and I'm hoping I get lucky and just need a shifter bushing as it looks like it is a common problem. sounds like I need to look on ebay if I need one or I saw a post about Toyota siper linkage bushings from Advanced Auto will work in a pinch. the steel one sounds better. also read where someone used a bolt, nut and a few washers. I'll check it out tomorrow night after work and hopefully get to the root of my problem.
Old 02-28-2009, 09:02 AM   #3
aa4lr
aa4lr has a spectacular aura aboutaa4lr has a spectacular aura about
The center console should come up with just four screws removed, two in back, two in front.
If it is the shifter bushing (which is likely), you may be able to do a temporary fix using two or three wire ties to hold the shifter cable end over the ball.
I would recommend the shifter bushing replacements sold on eBay -- either the Delrin or the Stainless bushing -- your choice.
I cannot recommend the Toyota wiper bushings. I tried them for about three months, and the bushing was so tight it worked the end off of my shifter cables. I opted to replace the cables entirely -- a $260 part from the dealer. The cables come with a new shifter bushing.
Good luck!
Bill Coleman
2001 Saturn SC2 Auto (3/13-...) "Yellow"
1999 Saturn SL2 Auto (11/09-...) "White"
1995 Saturn SC1 Manual (9/08-...) "Gold"
1994 Saturn SL1 Auto (7/94-1/04) 144,000 miles "Green"
Add to aa4lr's Reputation
Rate the quality of this post and help aa4lr reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
aa4lr is offline   Reply With Quote
Old 02-28-2009, 12:44 PM   #4
madpogue
1996 SW2
Dorman (aka Motormite "HELP!") now makes a bushing for our cars. Part #14043. No word on the forums yet as to its performance / quality / ease of installation.
Add to madpogue's Reputation
Old 02-28-2009, 01:57 PM   #5
metz281
metz281 is on a distinguished road
1997 SC2
dont forget to check the transmission end as well. The clips lose their grip after have the transmission removed several times (for clutch job) and can pop off. Make the shifter feel like a wet noodle. LOL There are 4 clips, One holds the cable to the case, and the other holds the cable end to the linkage, on both linkages. Have an assistant work the linkage and make sure its all hooked up before you rip out the console.
Add to metz281's Reputation
Rate the quality of this post and help metz281 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
metz281 is offline   Reply With Quote
Old 02-28-2009, 02:14 PM   #6
+1^^^ Check drawing.
binding shifter and shift linkage? Melissa_M S-Series Tech 26 12-02-2009 07:17 PM
Shifter cable/linkage issues Slammin96 S-Series Tech 25 10-02-2009 01:16 PM
shifter linkage connection on 98 SL1 abinder S-Series Tech 0 05-26-2009 08:29 AM
'99 SC1 Shifter Linkage Buck4U S-Series Tech 6 03-20-2008 11:09 AM
1997 SL2 Throttle Linkage Lub? Bartolo S-Series Tech 4 12-19-2007 02:11 PM
