Old 07-14-2011, 11:53 AM   #1
maxpower_454
maxpower_454 is on a distinguished road
2001 SL2
Default P0327 Knock Sensor
I am getting this trouble code intermittently. Does this mean my knock sensor is bad or that my engine is knocking???
Add to maxpower_454's Reputation
Rate the quality of this post and help maxpower_454 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
maxpower_454 is offline   Reply With Quote
Old 07-14-2011, 11:59 AM   #2
adventureoflink
adventureoflink's Avatar
Default Re: P0327 Knock Sensor
http://www.obd-codes.com/p0327
this'll give you some information on how to tackle this problem. Basically the knock sensor detects if a cylinder is knocking, or otherwise exploding a air/fuel mixture in a way that delivers less power and can cause damage to the engine if prolonged.
TL;DR, possible causes:
The knock sensor is faulty and needs to be replaced
There is a wiring open/short/fault in the knock sensor circuit
The PCM/ECM has failed
TL;DR, possible resolutions:
Verify the resistance of the knock sensor (compare it to factory specs)
Inspect for broken/frayed wires leading to the sensor
Check the wiring and connections leading to/from the knock sensor and PCM/ECM
Verify proper voltage is reaching the knock sensor (e.g. 5 volts)
Verify proper grounding of sensor and circuit
Replace the knock sensor
Replace the PCM/ECM
97 SL2
DOB: 3/19/97
Date Obtained: 5/30/07
Status: Alive, 1/2 exhaust
2004 Merc G.Marquis GS
DOB: 2/4/04
Date Obtained: 7/6/12
Status: Alive, no heat
Old 07-21-2011, 10:03 AM   #3
maxpower_454
2001 SL2
Mine really comes and goes. It has stopped doing it now so I guess I'll just ride it out until I get a consistent CEL.
P0327 Knock Sensor Low? BrownSaturn S-Series Tech 0 05-17-2010 01:41 PM
DTC Code P0327 Knock Sensor scaragon Ion General 5 09-04-2008 04:39 PM
Knock sensor MikeNW S-Series Tech 6 08-05-2008 11:38 AM
knock sensor Psyco88 S-Series Tech 0 03-31-2008 08:54 PM
what solves excessive spark knock (besides knock sensor) geartooth94 Miscellaneous Tech 15 09-26-2004 08:36 PM
