Old 12-29-2005, 11:48 PM   #1
pasha
pasha is on a distinguished road
1996 SL1
Arrow Gas smell inside the car...after fueling
Today, after I filled the gas tank and started the car I felt strong smell of gas inside the car. Could this be a problem with the carburetor. Also, last week the Starter of my car was changed because it was not starting in the morning,
Does anyone has a clue of what might be the cause?
Add to pasha's Reputation
Rate the quality of this post and help pasha reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
pasha is offline   Reply With Quote
Old 12-29-2005, 11:52 PM   #2
JarredW
JarredW is on a distinguished road
JarredW's Avatar
2007 ION-2 Quad Coupe
Default Re: Gas smell inside the car...after fueling
sure it wasn't from your hands, or clothing. and EFI engines don't use carbs
Add to JarredW's Reputation
Rate the quality of this post and help JarredW reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
JarredW is offline   Reply With Quote
Old 12-30-2005, 12:01 AM   #3
JS593
JS593 is on a distinguished road
JS593's Avatar
1992 SL1
check ALL your fuel lines, make sure there are no leaks.
92 SL1 SOHC TBI
Custom intake
Alpine deck, speakers, amp
JBL Sub
Ultimate amp
Volometer gauge mounted in dash
Magnaflow exhaust
....DEAD.... Car towed away Jan 18 2007. RIP
Add to JS593's Reputation
Rate the quality of this post and help JS593 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
JS593 is offline   Reply With Quote
Old 12-30-2005, 12:08 AM   #4
pasha
1996 SL1
Arrow Re: Gas smell inside the car...after fueling
I suspected the same. Therefore, I checked myself thoroughly, but the smell was not coming from my clothes. However, the smell dissipated later on. I'll check again in the morning. If I feel the same then I'll post a reply, otherwise, if I feel the same smell on the next refuelling, i'll inform you guys.
Old 12-30-2005, 12:33 AM   #5
justin_zink
justin_zink is on a distinguished road
1995 SL
You could have a hole in the filler neck.
Add to justin_zink's Reputation
Rate the quality of this post and help justin_zink reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
justin_zink is offline   Reply With Quote
Old 12-30-2005, 04:24 AM   #6
wolfman
wolfman's Avatar
Last time I chased a problem like this down, a genius had drilled a hole through the floor behind the rear seats to mount a subwoofer box...right into and through the top of the gas tank underneath...
Add to wolfman's Reputation
Old 01-01-2006, 01:29 PM   #7
MiSaturn
MiSaturn is on a distinguished road
2002 SL
1991 SL2
Sounds dumb, but whenever I'd had the smell of raw gas in a vehicle,
I later found out I'd spill some on my clothes.
Add to MiSaturn's Reputation
Rate the quality of this post and help MiSaturn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
MiSaturn is offline   Reply With Quote
Old 01-01-2006, 03:02 PM   #8
JarredW
JarredW's Avatar
and gas is weird because at first you might not thinkits you because the smell lifts off the clothes. usually if i spill some on me i can only tell its me if i go into a room away from the car.
Gas smell in car Urespa1 L-Series Tech 1 10-16-2008 07:57 PM
Help- Gas smell in car lasatgrl S-Series Tech 7 12-21-2006 01:53 AM
Smell gas when I get out of the car jcmartin86 S-Series Tech 3 12-16-2006 03:21 PM
Gas smell from rear of car jystickman Vue General 0 12-31-2003 02:50 PM
Smell of antifreeze liquid inside the car from a vent Orest Vue General 11 06-11-2003 08:30 AM
