Old 03-09-2008, 11:56 PM   #1
Donny
Donny is on a distinguished road
1998 SW2
Default 98 SW2 A/C pressure switch
Quick question...
My A/C is no longer blowing cold air as the compressor isn't turning. I checked the continuity of the A/C pressure switch (drivers side over the wheel well next to the fuse box) and there is no continuity. I'm thinking this means I'm low on refridgerant which turned this switch off, hence preventing the compressor from engaging. correct?
Thanks,
Don
Add to Donny's Reputation
Rate the quality of this post and help Donny reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Donny is offline   Reply With Quote
Old 03-10-2008, 02:02 AM   #2
Robman
Robman will become famous soon enoughRobman will become famous soon enough
Robman's Avatar
2001 L-Series 2.2L Sedan
Default Re: 98 SW2 A/C pressure switch
Sounds correct. Next time you might get a faster response if you post in the S-Series forum. This is the L-Series forum. Kthxbye.
Rob
2001 Turbo L200
1997 F150 XLT
1985 Range Rover Classic
1999 Yamaha Blaster YFS200
Do It Yourself
Add to Robman's Reputation
Rate the quality of this post and help Robman reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Robman is offline   Reply With Quote
Old 03-10-2008, 02:15 AM   #3
Donny
1998 SW2
Oops, sorry about that. I'm guessing it's the same deal either way.
Bad A/C pressure switch? strongboy2005 S-Series Tech 11 05-16-2014 10:44 AM
a/c pressure switch bypass paulbol L-Series Tech 3 06-15-2009 12:53 PM
Oil Pressure Switch SLAPSHOT Vue General 3 01-10-2009 10:18 AM
a/c hi pressure switch hobbs L-Series Tech 1 10-04-2005 10:50 PM
Oil Pressure Switch Steve96SL2m S-Series General 2 09-03-2003 11:23 PM
