#1 | ||||
![]() I have the resonator off and am about to put a new one on. While I have it off, I can shine a light inside the catcon.
Should I be able to see anything inside of it that would indicate if it's going bad or not? I've given it a good shake and don't hear anything rattling around. Thanks.
#2 | ||||
![]() All I can see in there is a screen inside the tube. I've given it another good shake but don't hear anything.
No codes or anything. Just checking while I have this thing apart.
#3 | ||||
![]() Thats not actually a screen , but the hundreds of tubes that make up the 2 biscuits in there.
If its not rattling, it should be fine. ... 92 SL1 original owner 94 SL2 Homecoming 98 SC2 White Hot 02 SC2
#4 | ||||
![]() Describe "rattle". I'm hearing something, but I can't tell if it's just the flex tube making noise. It's a bit of a metallic sound. I wouldn't say it's coming from inside the CatCon.
#5 | ||||
![]() If one of the biscuits has broke free it will flop around inside when you shake it.
There is a great video on how converts are built and work. Its quite informative and should give you a better idea of how its built. Over at sellyourcatsdirect in the video section. ... 92 SL1 original owner 94 SL2 Homecoming 98 SC2 White Hot 02 SC2
#6 | ||||
![]() OK...no sound at all. What I was hearing was the O2 sensor wire brushing against the heat shield. All's good now. Thanks for the heads up on what to be listening for.
#7 | ||||
![]() Join Date: Jul 2011
![]() My exhaust started shaking a couple day's ago....haven't checked if it's just something loose down there(that's what she said), or if the cat is going bad which would suck.
Bad Catalytic converter? | Mgg4591 | S-Series General | 3 | 01-24-2010 09:34 PM |
catalytic converter | packer_rich | Vue Red Line | 1 | 12-21-2008 08:09 PM |
catalytic converter | afcs | S-Series Tech | 5 | 02-16-2007 11:40 AM |
Catalytic converter? | KJB | Vue General | 5 | 07-14-2004 01:18 PM |
Catalytic Converter | Evil_Oppie | Ion General | 6 | 07-14-2004 01:40 AM |
