Old 05-15-2006, 03:42 PM   #1
d3ad1ysp0rk
d3ad1ysp0rk will become famous soon enough
Default Thermostat/ECTS issue
Situation:
Ca.r ran at 1/4 since I can remember. Decided I needed to fix that before the hot weather came (and with it, the potential for overheating).
Replaced the ECTS, felt a slight difference, but no temp change.
Replaced the thermostat, and the temp then started to go to 1/2 and a bit more, and the fan did work.
Night after I fixed it, I got home and shut my car off, and the fan wouldn't stop. It took roughly 5 minutes for it to turn off, which is very unusual.
I ended up having to keep filling the coolant with water because I was low (found a leak a few days later) and the light kept coming on.
Finally, after fixing it, I thought I was ok. Then I realized after all this, my temp now reads 1/4 again, at the max.
Any ideas? Would the thermostat die that quickly?
Add to d3ad1ysp0rk's Reputation
Rate the quality of this post and help d3ad1ysp0rk reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
d3ad1ysp0rk is offline   Reply With Quote
Old 05-15-2006, 04:22 PM   #2
Ken Benson
Ken Benson is on a distinguished road
1997 SC1
Default Re: Thermostat/ECTS issue
You shouldn't have anything to worry about. If your gauge has always read at 1/4, and continues to do so now that the leak is corrected, the car should be fine.
Temp gauges on cars aren't calibrated to all read at the same level. My temp gauge always runs at just a bit under halfway, but that doesn't mean your engine is only half as hot as mine, for instance. If your temp sensor *NEVER* moved off cold, or seemed stuck in one spot whether the engine was hot or cold, only then would I worry.
Changing the ECTS from the old resin type to the brass type is good, and it sounds as if you noticed some improvement already, but that wouldn't affect where the gauge would point thereafter. It certainly didn't affect my car.
The fan staying on after shutting off the car is normal, as it is computer driven, not ingition driven.
If your leak is fixed and the coolant level stays constant, you should be all fixed for the summer.
Add to Ken Benson's Reputation
Rate the quality of this post and help Ken Benson reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Ken Benson is offline   Reply With Quote
Old 05-15-2006, 05:14 PM   #3
d3ad1ysp0rk
Unfortunately, I don't hear the fan anymore. Even after lots of hard driving and or highway driving.
My confusion mostly arises from the fact that the temp problem was "fixed" for a bit, and now it's not anymore.
Old 05-15-2006, 05:35 PM   #4
Ken Benson
1997 SC1
The fan shouldn't come on all the time, only when the temp goes up around a 1/4 mark over where it normally would sit warm. Certainly, that is my case, and that seems to be concensus from what I've read on the forums.
Does it seem to overheat without the fan ever engaging? If so, something is obviously amiss. Also, if equipped, does the fan come on when you engage the AC? If it comes on, then the fan works.
Highway driving actually keeps the engine cooler, as you get great air flow to the radiator. A good test would be to start it and let it sit with poor air flow. If the gauge goes hot without the fan starting, there's a problem somewhere. You may want to check the cooling fan fuse and relay just to be sure. If the fuse is toast, that should be obviously burned up. Swap the relay with another relay and see if it helps matters.
Old 05-15-2006, 05:52 PM   #5
Actually, the fan may not go on until you're well into 3/4.
Have you FIXED (not just found) the leak yet? If so, and if it's no longer losing coolant, and the gauge is reading normally, why do you think you still have a cooling problem?
BTW, your coolant mix is probably weak, and that MAY affect the gauge reading. Get your mix back up to 50/50 (which it needs at all times, to properly protect the engine), and see what happens from there.
Add to madpogue's Reputation
Old 05-15-2006, 07:21 PM   #6
PlasticCarsRock
PlasticCarsRock's Avatar
They should all read similar, with respect to generation.
first gens sit at just under 1/2, after 1995, they recalibrated it, and it sits closer to 1/4
Old 05-15-2006, 08:02 PM   #7
kthane
kthane is on a distinguished road
1999 SL1
I think the issue here is that nothing was ever broken. Mine has never gone much above the quarter mark since the day I drove it off the lot brand new. Only time it went over half was when my electric cooling fan died. And it only got hot if the A/C was on. Of course computer cut off A/C as engine temp got to 3/4. Only time I've ever heard my cooling fan on is sitting at idle with the A/C on.
Add to kthane's Reputation
Rate the quality of this post and help kthane reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
kthane is offline   Reply With Quote
Help please on bolt sizes Thermostat and ects lxmustang89 S-Series Tech 3 12-30-2008 02:01 PM
ECTS or Thermostat 1996 SL lg540 S-Series General 14 03-01-2007 12:17 PM
New ECTS + New Thermostat AceDerry2 S-Series Tech 2 02-06-2007 10:54 AM
ECTS/Thermostat question The Critic S-Series Tech 3 04-19-2006 08:54 AM
ECTS vs. Thermostat? joshjani S-Series Tech 5 03-17-2005 12:27 AM
