Old 08-31-2007, 10:08 AM   #1
RedVision_350
RedVision_350 is on a distinguished road
Default Possible Thermostat Issue?
Another recent problem among many for my car. Anyway, yesterday I dropped my little sister off at school, and not even a 1/4 mile away is an intersection which I was sitting at. My SES light came on, and it always comes on (Don't have a code reader), but only during peak temperatures. I saw my temp indicator was past the 3/4 mark and on it's way to the red zone. I pulled over, let it cool, and got home. For the remainder of the day I used my dad's truck. I checked under my car and all around the engine bay for some kind of leak, although it might have evaporated since it was hot. All the hoses are in good condition. My radiator fan is working, and nothing is cracked or damaged (That I can see). Once the engine got hot, the temp indicator would go half way, then drop a little bit and show an SES light, and it would hold somewhat steady. This morning I took it to autozone, they read codes but couldn't help me with my overheating issue. When I started my car to leave, I don't know why, I just turned on the AC. As soon, and I mean right after, the AC turned on the temp reading shot down to the first mark, 1/4. So I'm thinking I have a bad thermostat.
*Sorry for long post, but I wanted to give as much information and detail. Also, the codes were 35 and 49, 35 being a faulty IAC, and 49 was a vacuum leak. I'm not sure if these readings are accurate and I'm not sure if they're related. Thanks for reading.
*EDIT* Ok also the other thing is that the times that I had the overheating issue I did NOT have the AC on.
Add to RedVision_350's Reputation
Rate the quality of this post and help RedVision_350 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
RedVision_350 is offline   Reply With Quote
Old 08-31-2007, 10:46 AM   #2
WingsOfSaturn
WingsOfSaturn's Avatar
Default Re: Possible Thermostat Issue?
Year and model? Have you ever changed your ECTS?
97 SL2 AT 150K Original Owner
95 SL2 MT 220K+
My Saturns have BRASS ones!
Old 08-31-2007, 11:26 AM   #3
kornphlake
kornphlake is on a distinguished road
It could be a bad thermostat, if turning on the A/C (which turns on the fan) brought the temps down that much. This time of year it's not uncommon for the temperature gage to get up to 3/4 in slow traffic, even just sitting through 2 cycles at a signal I've noticed my temperature gage creep up pretty quickly. I don't think the fan even comes on until the temp is about 3/4 anyway, you may have been sitting at the stop light and saw the temperature gage rise and shut off the engine before the fan had a chance to kick in. Once the fan comes on it should stay on until the temperature falls below half.
I've seen more thermostats stuck open than stuck closed (I think they are designed to be fail-safe) a thermostat stuck open won't cause your vehicle to overheat, and it will let the engine temperature drop lower than the optimal operating temperature with sufficent air flow, do you notice your heater doesn't feel very warm on cold mornings? Are you certain your fan works? Does it come on when the engine is hot and the A/C is off?
Add to kornphlake's Reputation
Rate the quality of this post and help kornphlake reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
kornphlake is offline   Reply With Quote
Old 09-01-2007, 05:56 AM   #4
Phredawgy
Phredawgy's Avatar
the Code 35 could be causing code 49 and might be helped by a good cleaning of your throttlebody and IAC valve.....it could just be that you are panicking at seeing the needle going that far......what other symptoms are you getting that lead you to believe the car is overheating? What part of the country do you live in? It's not uncommon for the car to heat up while sitting like that.....but you probably turned the AC on right before the computer kicked the fan on anyway...which it is designed to do......
Add to Phredawgy's Reputation
3.0L Oil Cooler issue NOT fixed & steering issue Partymmudasti L-Series Tech 5 08-08-2008 09:48 AM
steering wheel issue??suspension issue?? i'm dumbfounded VTVUE Vue General 8 06-17-2008 07:54 AM
Post thermostat replacement issue. User Name! S-Series Tech 2 01-09-2008 01:53 AM
THermostat issue 95c2 S-Series Tech 5 09-01-2006 08:44 AM
Thermostat/ECTS issue d3ad1ysp0rk S-Series General 6 05-15-2006 08:02 PM
