Old 04-15-2007, 08:57 PM   #1
allen57
allen57 is on a distinguished road
Default hi and need help. blowing fuse
hi im new here, but i need help. i have a 97 sl2 dual overhead. i had to pull the motor to replace the connecting rod bearings. well i put the motor back in and im pretty sure i got the wiring right. but now when i try to put it the key in start position, i keep blowing out the 30A fuse in the underhood fusebox, its labeled ign 3. i removed all the wires from the starter, except the hot wire, and tryed again and still blew the fuse. i really dont know where to start looking.
allen57 is offline   Reply With Quote
Old 04-15-2007, 10:42 PM   #2
Varopriest
Varopriest is on a distinguished road
Default Re: hi and need help. blowing fuse
You might want to go back and check to make sure that you didn't get a wire pinched when you dropped the motor back in. If you did, disconnecting them at the starter won't accually keep you from blowing a fuse. As the problem will be before the starter. If all the wires are clear, try disconnecting alternator wires, I've had it blow ign fuses on other vehicles (non-saturn).
People rarely stay mad at a mistake made out of kindness!!!
Varopriest is offline   Reply With Quote
blowing fuse trailwart S-Series Tech 4 08-29-2005 08:54 PM
Keep blowing fuse devolic S-Series General 3 08-07-2005 12:58 AM
A/C fuse keeps blowing crossedwires S-Series Tech 1 06-09-2005 08:18 PM
fuse blowing` garyh_rosies Miscellaneous Tech 1 12-28-2003 11:46 PM
fuse blowing` garyh_rosies S-Series Tech 3 12-24-2003 06:36 PM
