#1 |
Can anyone confirm whether you can just replace the wheel bearings on a FWD vehicle versue having to replace the CV Joint? Are the bearings part of the CV joint assembly and need to be replaced as a unit? Is it more efficient or cost effective to do it a certain way?
#2 |
![]() Join Date: Feb 2006
1993 SL2
I believe you need to replace the hub and bearing as one (actually this might just be true with the rear hubs), but the cv joint is separate.
93 SL2 107k mi |
#3 |
![]() Join Date: Apr 2006
1998 SL1
No they are 2 completely seperate units. You take off the steering knuckle which contains the wheel bearings, leaving the CV shafts hanging which contain the outer and inner CV joints. You can change them seperately.
Hope this helps.
SL1 256,000kms and counting... 2001 Yellow SC2 comin out soon |
#4 |
![]() Join Date: Jun 2006
THis is true but if it has over 100K on it and the bearing is bad I would be very tempted to replace the half shaft too while it is apart because it would only add a few minutes to the job at most and save a possible headache later.
Bookmarks |
Wheel Bearing vs. CV Joint vs. ???? | nivlem7 | S-Series Tech | 25 | 08-02-2016 12:23 PM |
Wheel bearing, CV joint, or brakes | Ron2002SaturnSL | S-Series Tech | 10 | 11-03-2007 12:45 PM |
A few LCA/ball joint questions | oneharbour78 | S-Series Tech | 6 | 08-17-2005 08:15 PM |
Wheel Bearings or CV joint? | Derwood | S-Series Tech | 7 | 05-09-2005 10:43 PM |
CV Joint or wheel bearing? | BahnBurnr | S-Series General | 5 | 11-09-2004 02:47 PM |
