Old 04-14-2005, 04:23 PM   #1
SL2Dreams
SL2Dreams is on a distinguished road
SL2Dreams's Avatar
2004 ION-2 Sedan
1995 SW2
Default Suspension Noise
Ok before my car would always like squeek or clunk when I went over a "sharp" bump at a low speed, maybe at higher, but I can't hear them from tires/wind/engine noise. Anyway I jsut noticed the other day going about 40 if I hit a "sharp" bump it makes this noise that sounds like the air dam is hitting the ground (like if you scrape it on a parking block). By no means was it big enough of a bump for that part to hit the ground, nor is it loose.
Any idea what it might be?
SL2Dreams is offline
Old 04-14-2005, 05:07 PM   #2
ElPasoION
ElPasoION is on a distinguished road
Default Re: Suspension Noise
It's the bushings; my ION made the same noise (that scraping noise) until they got replaced.
They were quiet for a while, then this popping noise started up, so I got them replaced again. So far, they're quiet.
Your Saturn dealer will replace them under warranty.
ElPasoION is offline
Rear Suspension Noise drumr S-Series Tech 6 05-06-2013 07:53 AM
Suspension Noise when Cold Glasact L-Series General 6 02-13-2007 10:06 PM
Suspension noise?? Bevortho Vue General 10 04-16-2005 12:00 PM
Front suspension noise???? tominsky Vue General 6 10-08-2003 12:37 PM
Front Suspension Noise RUSS99SL2 Miscellaneous Tech 3 08-17-2000 02:34 PM
