#1 |
![]() Join Date: Aug 2003
suspension problem
Help...I have a few questions about my 2001 L200: -What is the bar that goes from the strut to the sway bar called? (This bar is causing a clunking noise in my front suspension. My father took a strap and tightened the sway bar to the frame of the car and the noise went away) -What needs to be replaced? Are there bushings or pins in this bar? -Can these be easily replaced? -Is this bar pressed into place and therefore needing a mechanic to replace the problem? -I am very handy with cars, and would like to fix this problem on my own? I am just confused as to what is causing the noise? Thanks |
#2 |
![]() Join Date: Jun 2002
Isn't your car still in warranty? If so, take it to the dealer, have them fix it for free.
85 GLH 367whp. http://www.saturnfans.com/forums/showthread.php?p=2261629#post2261629 00 Insight 72mpg |
#3 |
I wish it was. I have almost 50,000 miles on this car. I drive to work 150+ miles a day. I did take in while it was under warranty about 8 months ago and they could not find this problem. Now that time has past...I found it too late.
#4 | |
![]() Quote:
The piece from the sway bar to the strut is the sway bar link. Replaceble as a unit. Held in place by the nuts at the sway bar and the strut. When you order the link make sure that you get replacement nuts as well. To remove just remove the nuts, use a wrench on the link side to stop things from turning, there are flats.
A lousy day in paradise is still a day in paradise. |
#5 |
![]() ![]() Join Date: Aug 2002
2003 ION-2 Sedan
Slightly confused here, are you refering to where the sway bar mounts to the control arms or where the sway bar mounts to the frame? . I can't remember off the top of my head, but memory serving me correctly{and it rarely does} both have rubber bushings and are just bolted into place. If they're are the type I'm thinking of, both could be replaced in less than 20 minutes{cursing figured into the number
Save the Earth, Ban Slushboxes!!!!! |
#6 | |
![]() Quote:
And yes- it DOES get noisy when one of those joints blows.
-Andy 01 SL1 (2011-2014) • 99 SW2 (2002-2009) • 95 SL2 (1997-2002) 00 ROUSH Cougar V6 • 03 SVT Focus #2370 • 08 Mustang Bullitt #5389 • 2013 Fiat 500 Abarth |
#7 |
You can look at a diagram of the parts at awgolden.com
You'll have to drill down from the home page to find the proper line drawing of the parts. I believe you're talking about item 13 in the diagram, called a "LinK", $21.17 list, $16.51 discounted plus shipping. |
#8 |
The link is #13 in this diagram:
Bookmarks |
Help diagnosing suspension/steering problem. | cris_thomas | S-Series Tech | 6 | 07-21-2011 10:42 PM |
Possible Suspension Problem? | rieskimo | S-Series Tech | 4 | 08-28-2009 10:55 AM |
suspension problem | dubsl2 | S-Series General | 3 | 07-10-2006 06:52 PM |
Weird problem with suspension? | imtfox | S-Series Tech | 7 | 11-25-2003 03:39 PM |
suspension problem | ascharnberg | L-Series General | 7 | 08-28-2003 08:42 PM |
