Old 08-26-2003, 02:06 PM   #1
ascharnberg
ascharnberg is on a distinguished road
Dizzy suspension problem
Help...I have a few questions about my 2001 L200:
-What is the bar that goes from the strut to the sway bar called?
(This bar is causing a clunking noise in my front suspension. My father took a strap and tightened the sway bar to the frame of the car and the noise went away)
-What needs to be replaced? Are there bushings or pins in this bar?
-Can these be easily replaced?
-Is this bar pressed into place and therefore needing a mechanic to replace the problem?
-I am very handy with cars, and would like to fix this problem on my own? I am just confused as to what is causing the noise?
Thanks
ascharnberg is offline
Old 08-26-2003, 02:27 PM   #2
lostwages_ls2
lostwages_ls2 is on a distinguished road
lostwages_ls2's Avatar
Default
It is called the stabilizer link. Price should be around $30-$40. It has a ball joint at each end. 2 nuts hold it in place. 1 of the ball joints is worn.
Raise vehicle on hoist.
Remove wheel and tire assembly.
Remove stabilizer bar link to strut assembly bolt.
Remove stabilizer bar link to stabilizer bar bolt.
INSTALLATION
Install stabilizer link into vehicle.
Install stabilizer link to stabilizer bolt. Torque: 65 Nm (48 ft. lbs.)
Tighten stabilizer to strut assembly bolt. Torque: 65 Nm (48 ft. lbs.) NOTICE: Before installing wheels, remove rust or corrosion from wheel mounting surfaces and brake rotors. Failure to do so can cause wheel bolts to loosen in service.
Position wheel onto hub.
Install wheel bolts and tighten in a crisscross pattern. Repeat tightening pattern to make sure torque is correct. Torque: 125 Nm (92 ft. lbs.)
Lower vehicle from hoist.
Your Honor Student is merely a pawn in my Min Pin's diabolical world domination plot.
Obey the Min Pin
lostwages_ls2 is offline
Old 08-26-2003, 02:31 PM   #3
socketz
socketz is on a distinguished road
socketz's Avatar
Default
You go lostwages!
You sound like a Chiltons Guide spewing this stuff out.
Anyway, what do you think would cause the stabilizer bar to become loose ?
socketz is offline
Old 08-26-2003, 02:36 PM   #4
lostwages_ls2
Default
Cut and past from AllDataDiy.com
Could just be a loose nut.
Obey the Min Pin
Old 08-26-2003, 02:39 PM   #5
lostwages_ls2
Default
Here's a picture.
Obey the Min Pin
Old 08-26-2003, 04:47 PM   #6
ascharnberg
Default
wow...thank you so much! I cannot begin to tell you how much i appreciate this advice! you're awesome! thank you thank you thank you!!
Old 08-28-2003, 03:05 AM   #7
sdlynx
sdlynx is on a distinguished road
Default
Naaaaa!
I'M the loose nut!
sdlynx is offline
Old 08-28-2003, 08:42 PM   #8
Dach
Dach is a jewel in the roughDach is a jewel in the roughDach is a jewel in the rough
Default
How many miles on your car? Seems odd for an '01 to have that problem with less than 100k mi.
Dach is offline
Help diagnosing suspension/steering problem. cris_thomas S-Series Tech 6 07-21-2011 10:42 PM
Possible Suspension Problem? rieskimo S-Series Tech 4 08-28-2009 10:55 AM
suspension problem dubsl2 S-Series General 3 07-10-2006 06:52 PM
Weird problem with suspension? imtfox S-Series Tech 7 11-25-2003 03:39 PM
suspension problem?? ascharnberg L-Series Tech 7 08-28-2003 05:56 PM
