Go Back   SaturnFans.com Forums > Models > Saturn Vue > Vue Red Line
Old 06-25-2019, 10:07 AM   #1
carvinbassplyr
carvinbassplyr is on a distinguished road
2005 VUE Red Line
Default Rear Sway Link Torque Specs
Does anyone know what the torque specs are for the control arm portion of the rear sway link assembly? I have a feeling I severely overtightened them when I replaced them the first time and 1 has already gone bad. Thanks in advance!
carvinbassplyr is offline   Reply With Quote
Old 04-02-2021, 08:29 AM   #2
cykopat
cykopat has a spectacular aura aboutcykopat has a spectacular aura about
cykopat's Avatar
2005 VUE Red Line
Wrench Re: Rear Sway Link Torque Specs
Not sure if this helps.
Control Arm Pivot Bolts
Upper Control Arm:
- To Knuckle: 118 Ft-lbs 160 Nm
To Suspension Support:
- 12 mm bolt 81 Ft-lbs 110 Nm
- 14 mm bolt 118 Ft-lbs 160 Nm
Lower Control Arm 81 Ft-lbs 110Nm
Stabilizer bar link-to-lower control arm nut 132 in-lbs 15 Nm
Stabilizer bar link-to-stabilizer bar nut 35 Ft-lbs 47 Nm
Stabilizer bar bushing/retainer bolts 52 Ft-lbs 71 Nm
And I see this is from 2019. RiP
cykopat is offline   Reply With Quote
Tags
rear, suspension, sway link
Rear sway bar link? the_new_raceman S-Series Tech 18 06-22-2021 04:49 PM
Clunk in right rear not rear sway bar end link bushing.. littletunny Vue General 1 10-27-2011 09:54 PM
Torque Specs for Sway Bar Nut? tinsley207 S-Series Tech 3 12-15-2010 02:06 PM
Rear sway bar link Ryan from Ohio S-Series Tech 3 05-09-2007 06:24 PM
Odd looking new rear sway bar link PICS nmsaty S-Series General 11 04-25-2006 08:37 PM
