Old 10-02-2013, 05:48 PM   #1
kdhunter
kdhunter is on a distinguished road
1993 SL2
Default Flaky steering
All,
I've got a '93 SL2. Just replaced the tie-rod ends, wheel bearings and a bad brake line. The steering was loose enough prior to this, but now I find that it feels even worse.
Symptoms:
--Tires are squealing in the turns.
--Car attempts to steer itself over surface/level changes (ie. asphalt to concrete).
--Some play in wheels front to back (with them off the ground).
--I know the LCA balls are shot, I just can't afford to replace them yet.
--Frame is rusting out on drivers side, with a separated crack in front of the axle (might be able to weld together).
I've been reading some of the other posts with similar situations, but I would like suggestions for other components to check. With the frame rusting out it's really time to "put her down", but until more permanent employment comes along I keep applying bandages.
Thanks!
kdhunter is offline   Reply With Quote
Old 10-02-2013, 06:02 PM   #2
Default Re: Flaky steering
From your description of the location, that's the cradle that's rusting, not the spaceframe. Bolt-on part. That, and the shot control arms, will def. affect the precision of the steering. The play you describe also suggests that the sway bar end bushings are shot, and/or the bushings at the inboard end of the control arms.
So go look for as new a car as possible in the boneyard, hopefully one with fairly solid control arms and sway bar bushings, and a rust-free cradle. Remove the cradle with the sway bar and control arms in place (easier operation anyway) and swap in the whole kit and kaboodle. Worst case, you can't find one with good control arms, just grab the whole assembly anyway, buy some new CAs, install them to the cradle and sway bar while it's off the car, and again, install the whole assembly to the car.
Old 10-02-2013, 06:02 PM   #3
What kind of alignment has it gotten after you replaced the tie rod ends?
Bad LCA bushings will def go towards bad handling, as well as no alignment after doing TRE's and a soft engine cradle may allow enough movement in the LCA to create all kinds of havoc.
Old 10-02-2013, 09:36 PM   #4
bumpdraft
bumpdraft's Avatar
1998 SW2
Originally Posted by kdhunter View Post
All,
...I keep applying bandages...
I have a used set of TRW Control Arms with 15,000 miles on them.
If you want them for the cost of shipping...They will probably fit in a USPS Flat Rate box.
No, I don't have a FaceBook account.
Old 10-03-2013, 05:59 AM   #5
kdhunter
1993 SL2
Thanks to all for the suggestions... see replies below
madpogue - I'm not familiar enough with the frame to know the cradle or space (and my old Haynes book doesn't cover it). This may be a job beyond my skill set.
fetchitfido - No alignment (yet). Seems pointless until I can replace the LCAs, (that and not having worked for over a year and a half severely limits my budget).
bumpdraft - I may have to take you up on that offer. (Postage shouldn't be bad from Mich to Ind.)
Old 10-03-2013, 08:55 AM   #6
If you're concerned about the ability to swap out the cradle, it's easier than welding it. As said, it's all bolt-up parts; you could literally do it in a driveway with hand tools.
Old 10-03-2013, 10:47 AM   #7
bumpdraft
bumpdraft's Avatar
1998 SW2
That's what I figured.
Let me know.
I removed them while looking for a clunk and wobble while cornering. The clunk/wobble was the strut inserts loose in the tube .
Old 10-03-2013, 11:17 AM   #8
Just out of curiosity, what brand/flavor of struts? That's some craptastic mfg quality control....
Old 10-03-2013, 06:30 PM   #9
bumpdraft
bumpdraft's Avatar
1998 SW2
Carrera Strut Tubes with machined steel SPS interference-fit caps, Koni Inserts.
Operator Error Craptastic field assembly of components pounded to death on Michigan's roads.
All I needed to do was tighten the nuts. I had the air space in the tubes full of fork fluid** ( Hey! It's a fork, right?) so the clunking was muffled.
Honestly could not follow the World Universal Euro Instruction pictures.
The picture was trying to depict cleaning the interior of the tubes and applying thread-locker. I used anti-seize and filled them with fork oil
Old 10-04-2013, 03:03 PM   #10
bumpdraft
bumpdraft's Avatar
1998 SW2
Back to Flaky Steering:
Post #11 from DIYGuy:
http://www.saturnfans.com/forums/sho...d.php?t=164515
^I will be looking into this on my steering. I'm sure the bearing is worn^
Old 10-04-2013, 03:08 PM   #11
mattelderca
mattelderca will become famous soon enough
mattelderca's Avatar
1998 SC1
1996 SL
If you right click on the post number you can save the link directly to the post.
2000 SL1 freebie, my sons DD
1998 SC1 still running, FOR SALE cheap!
1996 SL, GONE but not forgotten
2005 Generic Silver Minivan (Kia Sedona)
2009 Nissan Sentra 2.0S
mattelderca is offline   Reply With Quote
Tags
1993, sl2, steering, suspension
Flaky Bumpers IONfan2 S-Series General 5 11-03-2008 12:57 PM
Flaky Cruise Control bigseacow S-Series Tech 12 08-21-2008 02:24 AM
Flaky Turn Signal/DRL bryceb04 Ion General 0 02-15-2007 09:08 PM
1998 SL2 - flaky headlights jtk6204 S-Series Tech 4 12-04-2006 12:10 AM
Flaky Fuel Guage joshjani S-Series General 0 04-21-2006 05:02 AM
