Old 09-04-2013, 08:25 PM   #1
jonp01
jonp01 is on a distinguished road
Default BTSI question - 1998 Saturn SL2
All,
I am having the issue of the BTSI not allowing me out of park on cold days so I just took off the console and disconnected the arm coming out of the BTSI to the shifter.
Is there any reason this is a bad idea? The car seems to shift in and out of gear fine.
Thx
jonp
jonp01 is offline   Reply With Quote
Old 09-04-2013, 08:46 PM   #2
2NDSOUT
2NDSOUT is a glorious beacon of light2NDSOUT is a glorious beacon of light2NDSOUT is a glorious beacon of light2NDSOUT is a glorious beacon of light2NDSOUT is a glorious beacon of light2NDSOUT is a glorious beacon of light
2NDSOUT's Avatar
1999 SL
Default Re: BTSI question - 1998 Saturn SL2
I'm sorry... and the BTSI is what???
Sorry, never heard of that acronym and I have been on these boards for over 10 years now....
Bryan
94SL2 HCE, "Pearl"
99 SL
94SL2 260K Miles
1/15
97SW2 266K Miles
2/15
Always
94SC1 340,501 Miles
Org. Engine/Auto Trans
2/97-10/08
Gone 3/12
92SL1
05VUE
91SC
Old 09-04-2013, 08:50 PM   #3
Something like Brake-Transmission-Shift-Interlock.
It's about as smart as removing the clutch safety switch on a 5spd. Won't cause problem's as long as you never, EVER, forget about having bypassed it.
Old 09-04-2013, 09:00 PM   #4
jonp01
I took the connector off the shifter and I can move the shifter but the car doesn't recognize it and stays in park so I reconnected it.
I guess I can disconnect the wires, huh?
I cannot seem to find a replacement part via the Internet and don't really want to go crawling through junkyards.
Any ideas? I know the cooler weather is coming up and I want to be able to shift out of park.
Thx
jonp
Old 09-04-2013, 11:07 PM   #5
Macgyver
You should be able to disable it completely as a quick fix. You’ll have to remember to put your foot on the brake when coming out park and you’ll also be able to throw the car in reverse at any speed, but I doubt it will be a problem.
Old 09-04-2013, 11:33 PM   #6
Thank goodness the legal community FINALLY got the auto industry on the stick with this world-saving device in the early '90s. For those old enough to remember the bad old days of the '70s and '80s, before the BTSI was invented, the meager little interlock between the shifter and the ignition key cylinder was the only thing keeping the civilized world from the rampaging ravages of runaway automatic transmissions laying waste to the land, leaving gory rivulets of sticky metallic-smelling pinkish-red fluid in their wake.
Life was hellish back then, thuggish autotrannies hanging out on street corners next to open barrels of burning god-knows-what, just waiting to ambush little old ladies and beat them about the head and neck with their own handbags. Fights would break out in bars over whether PRNDSL was superior to PRND32 or PRN(D)21, or floor vs. column shift. Crazed, shadowy men would loot auto supply stores at night, smashing out the windows just to grab and guzzle down a quart of their favorite brand of Type F. People would sponaneously combust, backing out of their driveways shifting from Park to Reverse without even the thought of the brake pedal entering their minds. Nowadays, people sleep peacefully at night, largely forgetting that they owe the sanity of their world to that BTSI little solenoid.
Are you sure you want to instigate a return to those dark ages, just for the convenience of being able to get your d@mn shifter out of Park when you want to actually drive your car? Do you want that on your conscience?
Oh, wait, what... none of that happened before the BTSI was introduced? Oh, um, sorry, wrong universe; never mind....
Old 09-05-2013, 12:27 PM   #7
Some threads of possble interest to you?
http://www.saturnfans.com/forums/sho...d.php?t=136548
http://www.saturnfans.com/forums/showthread.php?t=89847
Old 09-05-2013, 12:39 PM   #8
Jim97sl2
Jim97sl2 is on a distinguished road
Did you check the brake switch for proper position? Do that first then test the solenoid.
Also look at this thread for a testing overview if needed. (post #2)
http://www.saturnfans.com/forums/sho...d.php?t=193568
Jim97sl2 is offline   Reply With Quote
Old 09-05-2013, 11:03 PM   #9
Audi 5000 started it all...................in this little orb we live in.
BTSI Replacement h2oskiier222 Ion Tech 6 11-06-2013 12:54 PM
Help! Thermostat question 1998 Saturn SC tsalk221 S-Series Tech 8 08-09-2013 09:59 PM
'95 SL1 BTSI Issue tunedbysaturnsl S-Series Tech 5 08-09-2013 02:41 PM
Btsi mjkiefer Ion General 5 11-09-2010 01:12 AM
1998 saturn sl1 transmission question magnum2 S-Series Tech 4 03-29-2010 07:51 AM
