#1 |
![]() Join Date: Jun 2013
Hello,
I have a 2002 L series 4 Door with the 2.2 the car is a highway car and run around vehicle to save fuel. The Drivers side rear of the car is lower than the passenger, upon inspecting the car (have a lift) it appears the bushings in the knuckle are badly worn, and the lower one flops around. I am not convinced this is the sag however. Also the strut assembly is from a junkyard, bought car used, and cannot find any cracks in the spring so far. Also the outer portion of the tires, BOTH sides are scrubbed away while the last 1.5" on the inside still has tread. My plan of attack: New Struts, and mounts Replace knuckle bushings both upper and lower Adjustable lower control arms, Raybestos Please let me know if I am on right track, or what else to look for, this has me stumped as usually with a sag I can find a broken spring etc. |
#2 | |
![]() Quote:
I replaced the rear knuckle bushings on my own car 2 years ago. They needed replacement some years prior to that. Their badly worn status did not alter the ride height on my car so I agree with you - those bushings aren't the source of the altered height. The fact that the left rear of the car rides lower than the other side, and that you don't appear to have a broken spring, is certainly odd. Perhaps the strut currently on the L/R of the car was installed incorrectly and thus altered the ride height. There is some adjustment for that present there. Just in case you may also be planning to replace the front struts, I highly recommend that you use only the factory mounts. There are stories here in the forum - including one of my own - about bad aftermarket front strut mounts. If you're only doing the rear struts then aftermarket mounts are okay. ![]()
406K miles (engine replaced @ 375K). Biden/Harris predictions, '21 -'25: weak economy; weaker military; more terrorism; emboldened RED CHINA. Sadly, B & H have proved me correct. |
Bookmarks |
Sagging headliner..what to do?? | Midnight13 | S-Series General | 14 | 12-24-2010 02:10 AM |
Leaning L200 | skywolf | L-Series Tech | 4 | 09-09-2009 12:50 AM |
Leaning up the fuel mixture. | alleninpa | S-Series General | 25 | 10-21-2005 08:35 PM |
leaning out the a/f mixture | Oddjob | Mods and Performance | 8 | 07-03-2003 10:40 AM |
Leaning toward Green | pitboss | General Saturn Discussion | 8 | 11-13-2002 07:37 PM |
