#1 |
So after going to a shop, being told I need to replace the muffler and RR wheel bearing for inspection then going back to be told the LF wheel bearing, and both ball joints are bad (when they did an ALIGNMENT the 1st time...) I'm rather pissed off.
I've fixed everything but the LF wheel bearing...yet now with the new ball joint there's NO play in it. At all. WTF? Help? lol I'm so confuzzled... |
#2 |
![]() Join Date: Jun 2011
You should be able to hear a bad wheel bearing. I just had my RF done, it was making a "woop woop woop" noise when I drove. I've also done BJs and the only way I knew they were bad was when I'd hit a bump there would be a definite metal on metal bang. Jack the car up and put a pry bar between the spindle and control arm, if they move apart, the BJ is shot, can wiggle wheel/tire and look to see if the ball is floating around in the housing as well.
-Mike 1995 SL2 5spd - Stock/MP2 trans swap - 258,XXX miles - 38mpg @ 65mph 1987 Monte Carlo SS - 5.3/4L80E swap - 13.92@103mph - 19mpg @65mph - needs POSI |
#3 |
Yeah, I know the wheel bearing is bad. Been making noise for quite a while. No play though, which is odd.
There was tons of play at 12&6 and 9&3 before doing the ball joint, now there's none, which has me confused. I still want to change the bearing just to get it to shut up but shouldn't there be play in it to indicate that it's bad? |
#4 | |
![]() Quote:
(Beware of scalloped tire tread fooling you into thinking the noise is bad wheel bearings)
No, I don't have a FaceBook account. |
#5 |
well, then, change it already...
s3aturnr
"reno is a lot like maybury, except everyone's on crystal meth and prostitution's legal" - junior |
#6 |
My wheel had no play in it either when the bearing was shot, just making noise...
#7 |
A bad wheel bearing will change noise as you're going down the road and turn the steering wheel back and forth. If the sound changes or goes away when you're going around a corner, it's probably bad.
You can also remove the wheel and just spin the hub with your hand and feel it gritty or loose. shawn |
Bookmarks |
Wheel Bearing vs. CV Joint vs. ???? | nivlem7 | S-Series Tech | 25 | 08-02-2016 12:23 PM |
Wheel bearing, CV joint, or brakes | Ron2002SaturnSL | S-Series Tech | 10 | 11-03-2007 12:45 PM |
CV Joint and Wheel Bearing questions | batmobile | S-Series Tech | 3 | 12-08-2006 02:02 PM |
Steering wheel turned during ball joint removal | c5f8 | S-Series General | 15 | 05-01-2005 04:39 PM |
CV Joint or wheel bearing? | BahnBurnr | S-Series General | 5 | 11-09-2004 02:47 PM |
