Go Back   SaturnFans.com Forums > Reference Forums > Mods and Performance
Old 02-21-2003, 04:52 PM   #1
sc288203
sc288203 is on a distinguished road
sc288203's Avatar
1994 SC2
Question Camber Kit
Does anybody know where I can get a Camber kit for a '98 SC2?
I have a feeling I'll need it when I put my new coilovers on.
Thanks
Step
'98 Saturn SC2
Perverted-Justice.com - Keeping Kids Safe
sc288203 is offline
Old 02-21-2003, 06:42 PM   #2
project_sl-2
project_sl-2 is on a distinguished road
project_sl-2's Avatar
1993 SL2
Default
A couple companies make camber kits but you can only adjust the camber +/- 1 to 2 degrees. It won't be enough to correct you camber completely if your planning on slamming the car but it will help. You can find them on SPS or I've seen Sprint camber kits on ebay for about $65.
project_sl-2 is offline
Old 02-22-2003, 08:44 AM   #3
sellis
sellis is on a distinguished road
Default Camber kit
You can get a camber kit from Carrera Custom Products. (704) 841-2614
http://www.carreracustomproducts.com/
sellis is offline
Old 02-23-2003, 12:05 AM   #4
sc288203
sc288203's Avatar
1994 SC2
Default
We need to be able to adjust the camber, since the coilovers are adjustable up to 4." I want to go as low as possible. The 2" springs we had on there didn't make enough difference to need a camber kit, but we probably will if we go the full 4."
I can always return it if we get the coilovers on and find that we don't need the camber kit.
Now this may sound like a dumb question, but does a kit come with 4, or 2, or what? Will we need to do just the back, or the front and back?
(My husband's the mechanic, not me! I just drive the damn car!)
Step
'98 Saturn SC2
sc288203 is offline
Old 02-23-2003, 08:37 AM   #5
sellis
Default Camber Kit
I have no idea what types of strut housing you are using. Nevertheless, most after-market housings, the lower strut mounting hole is e-longgated or can be e-longated for camber adjustment. If I understand you correctly you are lowering the car 4" and this certainly will require camber adjustment. The fine tuning of the camber adjustment then should be done with the camber plate kit. Purchasing a camber kit and then returning it if you do not need it is something you would have to discuss with the manufacturer. However once you have installed the new coilover, you will be able to determine if you want a camber plate kit.
Good Luck!
Steve
sellis is offline
Camber kit? Or Just alignment? Yenko S-Series Mods 11 02-06-2008 08:35 AM
camber kit? Esca Ion Mods 9 03-10-2006 09:30 PM
Camber kit before lowing JS593 S-Series General 6 12-07-2005 11:00 AM
Camber adjustment kit.. L300GATTLINGGUN L-Series General 6 03-07-2005 11:26 AM
Progress Springs / Camber Kit Doug Ion General 2 10-30-2004 11:08 AM
