Old 06-28-2010, 10:04 PM   #1
Askspot
Askspot is on a distinguished road
Idea The Aura ride (solved)????
Well, after countless searching for new struts that would quite out (my ride...I know some of you say you don't experience what I did. On drop off's/bumps in the road. While I was going around a corner I would hear a chattering probably for the past 2.5 years.) I thought it was just crap suspension in my mind meaning struts.) Back to my probable solution. I went to advanced auto parts ( I know right) The guy there said first check the linkage between the swaybar and the strut tower for any clunk. I did that tonight and it proved to be so. I could replecate the sound by moving the linkage back and fourth on a smaller scale. That sound would definatly amplify with more pressure on it. So I'm going to replace my front linkage with these... http://www.napaonline.com/Search/Det...59999+3999999#
I called Napa and he confiremed that the way he saw it was the linkage in the Aura is not strong enough for the tight struts they have. If you push on the linkage either way it's incredibly flimsy. Aparently this Moog linkage is suposeed to be some of the best. If that linkage would bend that would send some of the road force back through the sway bar causing noise in the frame. (This was what I vaugly took away from the tech's thoughts) Don't hate if you don't agree please correct me. So I don;t sound like an idot next time
I'll update later this week after driving it around, who knows maybe it will improve some body roll slightly.
Askspot is offline   Reply With Quote
Old 06-28-2010, 10:06 PM   #2
Askspot
Default Re: The Aura ride (solved)????
Ok correction. That link won't work. You have to put in the Aura and 07... ect and find the swaybar link.
Old 06-30-2010, 09:59 PM   #3
Askspot
Update.
The sway bar links did make an improvment of my complaint that when you go over a big bump and turning that it would feel like the car is falling apart. The same to as when I went over a sizable fall off in thear road. The links are about 50% thicker than the stock ones and cannot be bent when pulled on to feel if the ball sockets in them were loose. The old ones did seem to be defective. After I took them out, the ball joints in them flopped around inside.
However this made a nice improvment, The next problem I am having is that when I am turning in a parking lot or something and go over some uneven pavment for small bumps. I get this quick chattering coming from the front end of the car. I can feel it in my steering wheel. I did check the tie end bushing but they didn't seem to move around. Is there still a possibility that they could be shot. The left boot of the bushing seemed like it was torn a bit. Could that be what is chattering?
Old 06-30-2010, 10:35 PM   #4
Askspot
This post from a G6 user is exactly what I am also experiencing. pleae help if anyone has experienced this. It's not supposed to be like this lol.
http://www.g6ownersclub.com/forum/sh...pension+rattle
Old 07-01-2010, 01:19 AM   #5
Askspot
Does anyone have two cents?
Old 07-02-2010, 02:47 PM   #6
Deep6
Deep6 is a splendid one to beholdDeep6 is a splendid one to beholdDeep6 is a splendid one to beholdDeep6 is a splendid one to beholdDeep6 is a splendid one to beholdDeep6 is a splendid one to beholdDeep6 is a splendid one to behold
Deep6's Avatar
2002 L-Series 2.2L Wagon
Might be a stupid thing but the bearings on the strut mount might be shot? Those bearings may have had the grease dry up and now minor high frequency bumps cause the shimmy felt in the steering wheel. Just a thought.
2002 LW200 MT 170K "Rare 5-speed"
2000 LS1 AT 283K "Served us well since 2000"
1993 SL2 AT 155K "Also Gone but not forgotten"
2012 Honda CBR 250R 4.7K "She can't take this from me"
Deep6 is offline   Reply With Quote
Old 07-02-2010, 05:46 PM   #7
Askspot
That could be. I think that could be my next small investment will be those bearings.
Old 10-28-2010, 12:42 AM   #8
08AuraXR
08AuraXR is on a distinguished road
2008 AURA XR
Spot, you said the swap bar linkages are larger on the Napa parts?
I found some parts from Napa, but I don't know that they look any larger, perhaps it's just a stock photo? Do you have any comparison pictures?
08AuraXR is offline   Reply With Quote
Tags
suspension
Strut recomendations/ touring ride/ -the aura ride Askspot Aura General 16 10-04-2013 09:09 AM
Lowering Aura ride issues? Askspot Aura General 16 04-09-2010 08:04 PM
Stalling solved janay3 S-Series Tech 6 10-28-2008 11:12 AM
Aura Vibration - Has anyone solved it? cyclone8794 Aura General 6 06-24-2008 10:50 PM
problem solved panama58 S-Series General 1 12-30-2005 09:50 PM
