#1 |
![]() Join Date: Jan 2010
2001 L-Series 2.2L Sedan
1994 SW1
94 Wagon that I inherited from my Mother. It started having issues last summer. Would start and drive strong but steadily had issues starting after it had sat. Flooring the pedal got it to start and then it would drive fine. Car sat for a few months and next time I tried to drive it I got it started but it would die at stops. I nursed it home goosing it at stops. Plugs looked shot so I replaced them. Checked codes and nothing shows but the 12 default. After I put the plugs in the car ran great down the road....turned around in the neighborhood and first stop I came to it died. Nursed it home again. Plugs are sooty. Checking ects and plug wires now...any other thing I should be looking at?
#2 |
Clean out the throttle body + butterfly valve and the EGR valve passageways, they will be all carboned up from having a bad ECTS.
Former DD: 1994 SC2 5spd. 190K, being sold to a friend 2005 Saturn ION 2 5spd. 73K 1995 Aquamarine SL2 1.9L DOHC 5spd. ~125K Miles |
#3 |
![]() ![]() Join Date: May 2004
>it helps to list salient parameters like :mileage; location driven ; garaged; amount body rust; model types....
>given a 'MATURE' vehicle , unused for some time ... -drain/refill with fresh fuel , the fuel tank? OR , AFTER other pressing maintenance issues , after draining the tank ,add about 3 gallons gasoline , and enough fuel injection cleaner for a full tank of gas ... to clean up the 15year-old injectors. -renew the fuel filter -check/measure/assess: (a) fuel pressure (b) EGR function {as with vacuum gage to see if stuck open} (c) compression test -remove ignition power pack, clean mating/mounting surfaces , etc. -after you operate the engine for an hour or few , drain and refill the crancase with fresh oil while renewing oil-filter. -renew 'PCV' valve -do the OBDI code-reading gig , or have a pro scan it. |
#4 |
![]() Join Date: Jul 2009
2002 SL1
Definitely check the ECTS. I was having all kinds of idle issues and engine problems before I replaced it. Clean all the sensors, and take a look at the ECTS. The tip had cracked. This may not be your only problem, but it might solve the stalling at stops, which is what my car did. If you replace the ECTS, let the ecu reset. I didn't do that and drove around on a new sensor but the computer was still sending info and compensating for a bad sensor, so it ran worse until I reset everything. Good Luck!
#5 |
Unlikely a "wet" TB like this one is carboned up. ECTS is prime suspect.
Bookmarks |
2002 Saturn L200 wagon A/C issues | chucke908 | L-Series Tech | 7 | 04-20-2012 11:15 PM |
I think that my wagon is mad at me | OldSkewlSW1 | S-Series General | 6 | 06-10-2009 10:31 AM |
2002 L300 V6 Wagon... some serious issues..help? | altais | L-Series Tech | 3 | 10-24-2008 07:48 PM |
Wagon Liftgate Auto-unlock Issues | fred2003 | L-Series General | 5 | 04-09-2007 08:15 PM |
93 Wagon | hyper | General Saturn Discussion | 6 | 10-18-2002 08:40 PM |
