#1 |
![]() Join Date: Apr 2008
i rebuilded my front caliper today. removed old brake fluid from the reservoir and replaced with the new fluid. Bleeded air all 4 wheels (rear right, left front, left rear and right front). the brake worked but it does not stop immediately as it performed before the change. it takes a little longer to stop. should i re-do the bleeding.
thanks. |
#2 |
![]() ![]() ![]() Join Date: Feb 2005
1999 SC1
Yes, air in the system is the most likely issue. Bleeding the brakes on my SC2 a couple of weeks ago, I had to go around the car about 7 times before it fully worked the air out.
Sadly, I then blew out a brake line later that night. ![]()
SaturnSeries.net owner |
Bookmarks |
Front brake caliper rebuild help | dddaaa | S-Series Tech | 13 | 09-14-2013 10:55 PM |
which caliper bolt for front brake pads loosens ? | copakeman | S-Series Tech | 4 | 11-22-2009 09:56 AM |
Front Brake Caliper Replacement | farescb | S-Series Tech | 6 | 07-31-2009 09:57 PM |
No brake pressure..Just replaced front Caliper | .kevin. | S-Series Tech | 18 | 05-23-2008 12:10 PM |
Front Brake Caliper Bolt specs | tfgorman | S-Series Tech | 9 | 01-17-2008 10:17 AM |
