Old 07-08-2009, 01:06 PM   #1
TheJode
TheJode is on a distinguished road
1997 SW2
1996 SW1
Default Sw1 to SW2 Suspension Swap
I have a 1996 SW1 which I put new struts on with lowering springs. I now have acquired a 1997 SW2. Does anyone know if I can swap those without any issues? I have checked some sites and have noticed that the struts for a SW1 is a different part number than for the SW2 so I am a bit nervous to do the swap. I am not really sure what the difference could be.
TheJode is offline   Reply With Quote
Old 07-08-2009, 01:08 PM   #2
PurdueGuy
PurdueGuy's Avatar
1999 SC1
Default Re: Sw1 to SW2 Suspension Swap
You can swap it, shouldn't be any issues aside from the normal stubborn bolt here or there.
SaturnSeries.net owner
Old 07-22-2009, 02:19 PM   #3
TheJode
1997 SW2
1996 SW1
Thanks for the reply. I have finally gotten around to getting the suspension swapped. The swap seemed to go fine. There are some rattly and clunky sounds coming from the rears. I checked and I need to replace a rear sway bar link. I have a used one from my parts car, so I'll have to see if that helps fix the noises or not. if it does I will look into getting new greaseable aftermarket ones. I've heard the Spicer(Dana) ones from NAPA are good and if I can't get them I can get the Moogs from another shop. Does anyone have a preference to any rear sway bar links?
Tags
springs, struts, suspension
Cruise from 97 SW1 fit 00 SW2 srapp S-Series Tech 4 09-24-2009 12:44 PM
Need Front Wheel Alignment Specs for 94 SW1 & SW2 groingo S-Series Tech 1 08-15-2009 01:55 PM
diff on a sw1 and a sw2 mroverkill S-Series General 4 06-21-2007 06:05 AM
Engine 1995-2001 SW1 Swap SaturnWagon S-Series Tech 5 05-05-2006 04:10 PM
SW1 SOHC to DOHC swap done! Low Saturn Mods and Performance 17 12-26-2003 12:00 AM
