#1 |
![]() Join Date: Mar 2009
I have a 1994 SL2 and Have just replaced the following:
Strut Mounts and Bearings Driver and Passenger Side Control Arms Driver and Passenger Side After getting an alignment I noticed squeaking when I turn. Doesnt seem to make a difference on how fast I go or how sharp of a turn I take. I believe it is the strut mounts and that there should havve been some grease or lubricant put on between the bearing/mount and the rubber ring that sits on top of the spring...am I wrong in thinking this and if not what kind of lubricant/grease should I get? Thanks in advance!!! |
#2 |
#3 |
I will definately try this out when I get home. Thanks again for the help!!
#4 |
Mine squeaked very loudly when I replaced my struts and strut mounts, but the squeaking is now going away. I figured it's just breaking in right now since its all new equipment. I even had it double checked by a mechanic and was told everything was installed correctly.
2001 SW2: 60k Miles @ 8/11 |
Bookmarks |
Tags |
mount, squeak, struts, suspension, turn |
manual shifter sqeaks... | 4DRFIRE | Ion Tech | 5 | 12-31-2009 02:34 PM |
Sounds when turning | birdieluvr76 | Vue Tech | 3 | 08-25-2007 09:22 AM |
Problem with engine turning on then turning off, everything is on radio, lights, air | fatimaknapp | Ion Tech | 6 | 12-28-2006 05:02 PM |
Sqeaks at only 130 miles? | 04AWDV6VUE | Vue General | 7 | 07-17-2004 10:11 AM |
Turning off | cmpcpro | S-Series Tech | 6 | 03-26-2003 08:37 PM |
