Go Back   SaturnFans.com Forums > Models > Saturn Vue > Vue Red Line
Old 11-21-2007, 10:57 PM   #1
saturn-pilgrim
saturn-pilgrim is on a distinguished road
2004 VUE Red Line
Default Soften 2004 Redline suspension
I would like to soften the ride in my 2004 Redline. Does anyone know if I can just substitute a non-Redline shock aborbers and\or springs?
Any ideas to soften the suspension to be more like a non-Redline Vue?
Victor
British Columbia, Canada
Black 2004 Vue Redline 3.5L V6
saturn-pilgrim is offline   Reply With Quote
Old 11-21-2007, 11:33 PM   #2
eRic 02sc2
eRic 02sc2's Avatar
Default Re: Soften 2004 Redline suspension
you could downsize the wheels/tire from the redline 18-inch wheels and 245/50-18 tires to the (V6) 17-inch wheels with 235/60-17 tires. that should soften it a bit. or put the non redline springs on yours.
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
Old 11-21-2007, 11:52 PM   #3
D C
D C is on a distinguished road
D C's Avatar
Sure, you can. But why would you? The Redline is still pretty soft and if you put the base dampers on with the Redline tires, it would probably not feel very good at all.
D C is offline   Reply With Quote
Old 11-23-2007, 03:52 PM   #4
Dante
Dante is on a distinguished road
Dante's Avatar
2004 VUE Red Line
Cheapest thing to do is run your tires at 32 PSI. I run at 38-40 all the time b/c it's too soft for me at 35. Next best thing is to buy tires with a taller sidewall, or buy 17" or 16" tires and wheels. The smaller your wheel, the goofier it will look though. Your handling will go to crap too. You could always find someone with a normal Vue that's willing to swap springs, or sell you their old ones off a non-RL, but the dampers/shocks probably won't have much effect. You can buy a set of aftermarket shocks and struts from Monroe, but again, it won't make much difference in teh "harshness"... that's pretty much all in the spring rate and how hard your tires/sidewalls are.
Tupperware cars FTW!!!
Dante is offline   Reply With Quote
Old 11-23-2007, 06:45 PM   #5
LUNCHBOX
LUNCHBOX will become famous soon enough
LUNCHBOX's Avatar
1993 SW2
1993 SC1
I would agree, you could basically non-RL the suspension and put the regular VUE 17's and springs on your suv. I think the car will look funny with the skinnier and smaller wheels and larger wheel gap though.
I guess the question I would have is, why did you buy a RL Vue instead of just a regular model??
1993 SC1.5 - 1993SW2
LUNCHBOX is offline   Reply With Quote
Old 11-23-2007, 08:07 PM   #6
BobbyP
BobbyP's Avatar
2006 VUE Red Line
2007 SKY
Do you think the 2004 Red Line has a stiffer suspension? First time I recall anyone complaining about the suspension being too rough.
2006 Black VUE Red Line - Now running iOS 14.7 beta
Old 11-25-2007, 03:15 PM   #7
zeissheadreggie
zeissheadreggie is on a distinguished road
Location: East point, GA(3 clicks outside of the atlanta city limits)
2005 VUE Red Line
2000 L-Series 3.0L Sedan
After having some tendonitis in both wrist and hands, I too began to think that
the ride was a bit "harsh". (there are also some poor street surfaces here in Atlanta). I solved this problem with a +1 size tire(245-55-18) as opposed to the OEM 245-50-18. The slightly taller side wall adds a bit more comfort to the ride, and vehicle height: and it fills the wheel wells nicely. Stay away from the BF Goodrich version of this tire, as it is very loud. I'm starting to wonder if I should return them because the are so loud. After I make sure that there's no issue with the suspension/wheel bearings, I'll make a decision as to if I should keep this brand of tire. Again, after two weeks, that the "+ 1" size appears to have made the difference for me. (my 2 cents worth.)
live fast, die young, and leave clean underwear!!
zeissheadreggie is offline   Reply With Quote
Old 11-25-2007, 05:46 PM   #8
TheSlayer
TheSlayer is on a distinguished road
Hey all! I would have to say that the Redline's ride is a lil rougher compared to the 2002 AWD V6 that my wife had. She now drives the RL daily and says it handles better, but it is a little harsher on the bumps. Of course that could be just West Virginia roads! Hey there still better than PA! lol I don't think its bad enough to want to swap suspension. I am running 225/55-18 Cooper CS4s and my wife says it made them slightly smoother on the bumps...not too much though. With an 80K treadlife warranty I couldn
t go wrong. Oh and I have to do it...... West Virginia in the National Championship!!!!!! WOOOO!!!
Bart "The Slayer" Sayers
TheSlayer is offline   Reply With Quote
Old 12-23-2007, 03:35 PM   #9
Rob Leigh
Rob Leigh is on a distinguished road
Greetings Saturn-pilgrim,
I have the old 2006 Vue V6 springs that my Eibachs replaced. You can have them - make me an offer.
The Eibachs lowered my Vue about 1.5" front and back. Does anyone know if they will fit a Red Line?
Rob
Rob Leigh is offline   Reply With Quote
Old 12-30-2007, 12:57 AM   #10
Dante
Dante's Avatar
2004 VUE Red Line
Rob
Sure will... several RL owners have them. The only difference between RL and regular suspensions is the spring rate and height, supposedly sportier shocks/struts, and the rubber spring cushion in the rear has a different part number between RL and regular... But so far as I know they are basically the same.
2004 3.5 Vue -- Suspension creaking noises silversaturnvue Vue General 8 01-21-2009 09:10 PM
2004 VUE Suspension issues LMPARD Vue Tech 2 02-03-2008 04:20 PM
2004 RL - Rear suspension/wheel question Xboxer Vue Red Line 1 01-15-2007 05:03 PM
Would Redline suspension bolt to QC? ktleborg Ion General 3 08-25-2005 01:32 AM
Redline vs. Standard Suspension LSLWSupplier Vue General 26 07-23-2004 03:45 PM
