Old 05-29-2007, 11:05 AM   #1
saturnchemist
saturnchemist is on a distinguished road
2004 VUE 2.2L
Dazed Left front suspension noise 2004 Vue w/VTi
I am a little scared (an so is my wallet) about an intermittent creaking in the left front suspension of a 2004 Vue 4cy front wheel drive with VTi. The car has 34K miles and is good condition.
Is this an ominous sign?
I am hoping it a bent strut, but my wife claims she hasn't run anything over. The car tracks straight and doesn't dive when braking.
Are there warning signs of an impending VTi failure?
Thanks
saturnchemist is offline   Reply With Quote
Old 05-29-2007, 12:49 PM   #2
BuckeyeBud
BuckeyeBud is on a distinguished road
Default Re: Left front suspension noise 2004 Vue w/VTi
Need some additional info in order to provide better answer.
Does the noise happen when turning or going straight?
Does the noise happend when going over a bump?
I went through the same questioning. I wound up changing the sway bar links (1 on each side). There was a pivot that was very stiff and would make a noise when making a right hand turn.
BuckeyeBud is offline   Reply With Quote
Old 05-29-2007, 12:53 PM   #3
kodak_jack
kodak_jack is on a distinguished road
kodak_jack's Avatar
It's not anything you or your wife did, it's the front suspension bushings or strut mounts. Unfortunately, the struts springs are involved with the strut mounts,so, they should be done by a person who knows how to compress the springs. An 04 might need new struts by now anyway. I assume it's out of warranty. Have both sides done at one time.
kodak_jack is offline   Reply With Quote
Old 05-29-2007, 11:33 PM   #4
If it is a moaning creaking noise then it is likely the front sway bar strut linbks siezing up. If it is more of a rubber on metal creaking noise then it could be the upper strut mounts.
Any warrenty left on the car?
Squeaky noise in front left tire Thelonius S-Series General 5 05-16-2007 01:06 PM
front left suspension knocking gord888 Ion Tech 2 12-01-2006 06:38 PM
Front Left Wheel Noise andyr13 Vue General 14 07-10-2006 07:10 PM
Grinding noise from left front under braking Eurosat1 S-Series Tech 2 06-28-2006 09:40 AM
left front pull, noise ktb S-Series General 5 09-01-2005 09:16 PM
