#1 |
![]() Join Date: Feb 2007
I feel most of the road and bumps when i drive, compared to other cars, my ride is really bumpy and annoying at times on some roads. I have a saturn ion 2004 . 16000 miles. How can i get a smoother ride?
#2 |
What other cars are you driving?
2005 Ion Quad Coupe 2 |
#3 |
![]() ![]() Join Date: Oct 2002
2008 Astra XR
2008 SKY Red Line
Check your tire pressure. If the car is lightly loaded, go to the lowest cold pressure or up to 5psi less.
If the car is an Ion 3, it has a slightly tighter suspension and shorter tire sidewalls(aspect ratio). You can alleviate some of the ride discomfort by going to a shorter rim and use a tire with a taller aspect ratio. |
#4 |
How many miles on your ION? Revised bushings were used from 05 on IIRC. I would not recommend taking air out of the tires unless they were already overfilled for safety reasons. (remember the Explorer? Tire failures were due to overheating which was partially blamed on underinflation- dealers were recommending taking some air out becuase of the crummy ride- sound familiar?) Have you recently replaced the tires with different brand? Not all tires ride the same due to different rubber compounds. If all else fails, take it to your retailer and have a tech ride along to see if he/she notices any unusual harshness. They drive different ION cars all day long so a 2nd opinion in person may help more than our internet speculation.
..aka GMinTheDriveway Former Saturn Sales Consultant Give me choices in powertrain, great handling and decent MPG and I will buy a Saturn again. |
#5 | |
![]() Join Date: Mar 2006
2005 ION-2 Sedan
![]() Quote:
#6 |
2006 ION-2 Quad Coupe
if the car was heavier it wouldnt be as bouncy also.. maybe go to a smaller rim bigger sidewalls?
VISIT MY CARDOMAIN --> http://www.cardomain.com/ride/2259877 s256 turbo, vulcan intake, exedy clutch, 8.9:1, camed, eagle rods, 2.4 tb, B&G coilovers, patriot head, stage 2 axels 418whp 2.2 :) |
#7 |
![]() Join Date: May 2007
2006 ION-2 Sedan
I've also noticed my 06' is pretty bouncy. Mainly in the rear. Basically bounces around like you'd feel in a pickup truck. It's a combination of having not enough weight back there and not having a strut/spring suspension setup like most cars.
#8 |
Buy a different car.
Member of the Crank Window Club |
#9 | |
![]() Join Date: Aug 2006
2007 ION-2 Quad Coupe
![]() Quote:
Light Travels Faster Than Sound Which Is Why A Person Can Appear Bright Until They Open Their Mouth. |
#10 |
My ION is not bumpy at all. If anything it's the smoothest riding compact I've ever driven. It might be because I have the 14 in wheels.
#11 | |
![]() Join Date: Jul 2004
2008 AURA XE
2006 VUE 2.2L
![]() Quote:
My OEM Firehawks are very stiff--with absolutely little or no sidewall flex. Of the cars I've driven over the years, I think the ION-3 is the best overall handling car I've ever owned. I experience very little body or tire roll, but it does ride like an ox cart in that every crack or small bump in the road is transmitted to the body of the car and I can feel it! With little doubt, I blame the stiff sidewall of these performance tires for that particular ride feature, but credit the same tires for the good performance type handling. In a way, I can't wait for these OEM tires to wear out, and when they do, I'm thinking of trying an H-rated touring tire or maybe a set of H-rated Goodyear Comfort Tread tires to improve the ride. I would offer the suggestion that if you have an ION-3 with OEM Firestone Firehawks, that you blame the tires and not the car for the ride. If my basic assumptions are correct, to get a smoother ride you will have to find a tire with a more flexible sidewall than a performance tire generally offers. ![]()
"The principle difference between a man and a dog is that if you take a dog in and make him prosperous, he won't bite you!" - Mark Twain 2008 Aura XE-4 2006 VUE 2.2L |
Bookmarks |
The bumpy road to newastra | newastra | Astra General | 13 | 07-17-2008 10:06 AM |
Bumpy Road .. Is it just me?? | ktravis | Vue Red Line | 8 | 03-02-2007 08:24 PM |
BUMP, BUMPP, BUMPY?? What do they mean? | meseville | S-Series Tech | 4 | 03-14-2006 03:11 PM |
Ride feels weird/bumpy | IONizedinblack | Ion General | 9 | 07-08-2004 12:07 AM |
bumpy road = rough idel | haplo06 | Miscellaneous Tech | 4 | 08-31-2002 09:28 PM |
