Old 12-05-2014, 09:12 AM   #1
ohiohouston
ohiohouston is on a distinguished road
2003 L-Series 2.2L Sedan
Dizzy 2003 L200 suspension problem
I have an '03 L200 with really bad inside tread wear on rear tires. I've been scouring the web trying to figure out what might be the cause, but I am very confused. I know the pre '03 L-series didn't have adjustable rear camber without modification, but I cant find anything on adjusting my '03 rear camber. Also, I know my upper control arm bushings are bad. Could this be the cause of my VERY uneven tread wear? Or do I need to look deeper? Any help is appreciated!
ohiohouston is offline   Reply With Quote
Old 12-05-2014, 10:52 AM   #2
s3nfo
s3nfo is a jewel in the roughs3nfo is a jewel in the roughs3nfo is a jewel in the rough
s3nfo's Avatar
2001 L-Series 3.0L Wagon
Default Re: 2003 L200 suspension problem
Yes, worn control arm bushings can lead to uneven tire wear. Do a search on L Camber bolts and you should get several threads on adjusting rear camber (requires drilling the mount holes oversize and installing eccentric bolts)
Jerry N
"Politics is the art of looking for trouble, finding it, misdiagnosing it and then misapplying the wrong remedies."
Groucho Marx
s3nfo is offline   Reply With Quote
Old 12-05-2014, 12:52 PM   #3
ohiohouston
Thank you. I think I'm going to try this. I just wasn't sure if I needed to because when I heard the problems with the suspension were fixed in 2003, I though they made it all adjustable.
Old 12-05-2014, 01:26 PM   #4
As shown below, and may be seen if severe, the tops of tires are tipped inwards to wear the inside tread more. Slotting strut holes will allow camber adjustment - I'm guessing the lower strut hole?
Old 12-05-2014, 12:22 PM   #5
Russet
2002 L-Series 3.0L Sedan
Have you take it to a shop to see what they can do as well? That should be something you should do as well besides trying to be a fix-all for your car there somethings a shop is better to fix then one can do themselves.
Old 12-05-2014, 12:49 PM   #6
ohiohouston
I've been reluctant to take it into a shop after hearing about how much money people have wasted on this suspension because its not adjustable. I just want to make sure I have any kit I need installed to make it possible to do a precise alignment before I send it in.
alignment, camber, l200, negative, suspension
2003 L200 problem(s) sherry.zaldivar L-Series Tech 1 12-26-2012 06:19 PM
2003 L200 - Oil/Transmission Problem Apikoros L-Series Tech 2 08-09-2012 04:10 PM
My L200 needs suspension work and I need advice (please :) BBL200 L-Series Tech 4 06-22-2010 10:18 PM
L200 Knocking Sound (Suspension) lymanhall44 L-Series Tech 7 10-10-2009 03:12 PM
2003 L200 Leak problem aprilflower L-Series Tech 7 01-25-2008 12:50 AM
