Old 04-06-2014, 10:25 AM   #1
Moskvitch
Moskvitch has a spectacular aura aboutMoskvitch has a spectacular aura about
Moskvitch's Avatar
2000 SL2
Default Front end clunk/clatter
Hi everyone,
I've got a real bad clunk/clatter on my front driver side. The clunk is not a big clunk but rather the sound of slack in some parts. It happens only at low speeds, on light bumps (anything that just shakes the car a little). Big bumps and potholes it doesn't make any sound. It will also do it sometimes when i change gear (just the slight offloading of the suspension sets it off).
It is however loud enough and happens often enough (at least 10-20 times every drive) to be causing a concern.
I have replaced all 4 struts with new mounts up front 3 weeks ago
LCA's on both sides were replaced last year
Car has just had an alignment after struts (Running -1.5 camber up front, -1.5 rear)
New inner tie rod end on passenger side.
To me it sounds like a ball joint, but i can't find any play in it. It did however look rusty when i looked at it (boot doesn't seal that well).
Any ideas?
Moskvitch is offline   Reply With Quote
Old 04-06-2014, 06:01 PM   #2
carfreak09
carfreak09 is on a distinguished road
1997 SL1
Default Re: Front end clunk/clatter
Check the anti roll bar bushings. The end bushings should have been replaced as part of the lower control arm replacement but there are two other bushings that hold the center of the bar. If any of these bushings are worn out, the bar will rattle around over small bumps.
carfreak09 is offline   Reply With Quote
Old 04-06-2014, 09:20 PM   #3
Moskvitch
Moskvitch's Avatar
2000 SL2
Thanks for your input. Although that didn't end up being the problem.
Figures i fix it after i ask the question right?
So it turned out to be the LCA was of poor quality and the cradle bushing had a lot of slop in it. Because of the sway bar, there was tension on it and it was impossible to see the play when the car was jacked up. Only when i completely removed the sway bar did i notice it.
Replaced it with a Moog LCA and also put in some poly swaybar to LCA bushings on both sides.
Steering has never felt better!
Old 04-06-2014, 11:52 PM   #4
sallydriver
sallydriver is a name known to allsallydriver is a name known to allsallydriver is a name known to allsallydriver is a name known to allsallydriver is a name known to allsallydriver is a name known to all
sallydriver's Avatar
1993 SW2
I was about to mention the fact some people's anti-roll bars were having the ends loosen, but I'm glad you fixed it!
1998 Red SL 5spd "The Right Honorable Duke Farnsworth the Functional of Syracuse":165,000 miles
1999 Forest Green SL2 5spd "Sally": 307,100+ miles
sallydriver is offline   Reply With Quote
ball joint, clunk, lca, suspension
front end clunk dakota1820 S-Series Tech 35 02-11-2019 05:30 PM
front end clunk BRIAN41920 S-Series Tech 4 04-05-2010 11:36 AM
Front end clunk 85_SS S-Series Tech 3 06-01-2006 10:18 PM
Front Suspension "clunk"/Wobbly Drivers Side front tire feeling TIMSPEED Miscellaneous Tech 10 07-06-2002 06:38 AM
Clatter noise from right front end joe Miscellaneous Tech 3 06-05-2002 06:32 PM
