Go Back   SaturnFans.com Forums > Models > Saturn Ion > Ion Mods
Old 06-28-2007, 09:45 AM   #1
snobrdrdan
snobrdrdan is on a distinguished road
snobrdrdan's Avatar
2009
2007 ION-3 Quad Coupe
Default How To: Tibbett/Photo Antenna Delete Mod w/Pictures
This is by far the best visual mod for FREE!
The stock antenna is in a weird location and there's no replacement antennas available that look halfway decent, but with this mod you can keep your stock antenna and get great reception still but it just won't be seen at all.
I take no credit for this mod, I just wanted to post a How To/write up for people wondering how to do it. It's very very simple and should take like 15 minutes.
Tools Needed:
T-15 Torx Bit
7mm wrench
10mm socket & ratchet
10mm wrench
Small slotted screwdriver
1. Take off the stock antenna using the 7mm wrench
2. Open the passenger door and you will see a T-15 Torx screw holding on the small black trim panel.
3. Unscrew it and then gently pull the panel towards the back of the car to remove it and put it aside. Then you'll see another T-15 Torx screw behind it and also a 10mm bolt.
4. Now you want to unscrew the 5 T-15 Torx screws on the underside that hold the top painted trim piece that goes alongside the windshield and towards the roof. Peel it back a little and then pull it forward towards the front of the car (there is a tab that slides into the rear piece). Put that piece to the side.
5. Now you want to remove the bolts that hold the fender on. There is one 10mm bolt under the cover you removed earlier.
6. Now open the hood & there are 3 10mm bolts & then one plastic body clip--use the screwdriver to pull up the pin in the middle and then pull the body of the clip out.
7. Now you can pull the fender carefully back a little and you can see the antenna mount
8. Undo both 10mm bolts holding the antenna base to the car with a wrench (a ratchet box wrench would be VERY handy here since there isn't much room to work with). Pull the base out & now you wanna flip the antenna plate over (so that it's facing outward instead of inward) and then screw the antenna back in
9. Now feed the antenna tip into the fender towards the corner lens. You can adjust it how you feel, but there's only 2 different places it can go and mine ended up going under a plastic headlight piece and is in there really tight (which is good)
10. Then you wanna put only one of the 10mm bolts back in (the top one) and then tighten it down.
11. Put the 4 bolts & body clip back in for the fender, then put the top roof trim panel piece back on, and then the little black corner piece.
12. Look at your work & enjoy!!
2009 VW GTI
FRO: 2007 Ion REDLINE -- 8/06-3/08
2008 Aura XR -- 3/08-8/08
Add to snobrdrdan's Reputation
Rate the quality of this post and help snobrdrdan reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
snobrdrdan is offline   Reply With Quote
Old 06-28-2007, 09:46 AM   #2
snobrdrdan
snobrdrdan's Avatar
2009
Default Re: How To: Tibbett/Photo Antenna Delete Mod w/Pictures
Before & After Pics:
2009 VW GTI
Old 06-28-2007, 11:51 AM   #3
bc3tech
bc3tech will become famous soon enough
bc3tech's Avatar
2007 AURA XR
i vote RLF ban for actually reposting to SF...
+rep always appreciated!
The Procharged Ion - http://kickassion.bc3tech.net
16.317s @ 85.30mph (Nearly stock)
188.28whp / 175.03wtq - SMP Stage 2 - 10psi
Add to bc3tech's Reputation
Rate the quality of this post and help bc3tech reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bc3tech is offline   Reply With Quote
Old 06-28-2007, 02:00 PM   #4
migs1974
migs1974 is on a distinguished road
migs1974's Avatar
2003 ION-2 Sedan
what the hell is "Tibbett/photo"?
poop
Add to migs1974's Reputation
Rate the quality of this post and help migs1974 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
migs1974 is offline   Reply With Quote
Old 06-28-2007, 03:00 PM   #5
yukisho
yukisho is on a distinguished road
yukisho's Avatar
Wasn't a need to repost this at all. But it forced me to spend the 20 minutes outside in this heat doing it lol.
[url=http://www.cardomain.com/ride/2621639]Check Out My Ride[/url]
Add to yukisho's Reputation
Rate the quality of this post and help yukisho reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
yukisho is offline   Reply With Quote
Old 06-28-2007, 07:03 PM   #6
snobrdrdan
snobrdrdan's Avatar
2009
They are the guys (Tibbett & Mrphoto) on redlineforums that came up with this mod
2009 VW GTI
Old 06-28-2007, 07:05 PM   #7
snobrdrdan
snobrdrdan's Avatar
2009
And WTF?????
Not everyone has a redline and is on the redline forums so I thought I'd post this up for the regular Ion owners too
It's a free mod & makes the car look better.....geesh
2009 VW GTI
Old 06-28-2007, 07:08 PM   #8
snobrdrdan
snobrdrdan's Avatar
2009
Also, if you wanna fill in the hole from the antenna.....you can go to ACE hardware and pickup a 3/4" nylon cap/plug for $0.65
It's in the hardware (nuts, screws, bolts) aisle in the little plastic drawers where you can buy everything individually
Looks a lot better & finishes the clean look (mounts flush)!!! It's in there super tight and isn't going anywhere and matches the cowl perfectly too!
pics:
2009 VW GTI
Old 06-28-2007, 07:12 PM   #9
btrfl1562
btrfl1562 is on a distinguished road
I didnt know that antennas bothered people enough to try and figure out how to remove them. Its not like they are in the way of anything.
I will admit that the little antenna nub on the rear portion of the drivers side roof DOES annoy the hell out of me....its not centered
Add to btrfl1562's Reputation
Rate the quality of this post and help btrfl1562 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
btrfl1562 is offline   Reply With Quote
Old 06-28-2007, 08:10 PM   #10
snobrdrdan
snobrdrdan's Avatar
2009
I don't mind the little OnStar antenna....I think it's cool
I just couldn't stand the radio antenna.....it's tall and ruins the side profile of the car.
Plus there aren't any options for an aftermarket/shorter one that looks decent.
And this mod just relocates it.....you don't lose reception & it's free
2009 VW GTI
Old 06-29-2007, 05:25 PM   #11
yukisho
yukisho's Avatar
I am gonna get an audi fin and encase mine in it in the center back.
Old 06-30-2007, 01:40 AM   #12
snobrdrdan
snobrdrdan's Avatar
2009
For whatever reason it will not let me edit my original post, but it's really a 7/8" Nylon Hole Plug & I included 2 pics of what it looks like
Originally Posted by snobrdrdan View Post
Also, if you wanna fill in the hole from the antenna.....you can go to ACE hardware and pickup a 7/8" nylon hole plug for $0.65
pics:
2009 VW GTI
Old 07-01-2007, 02:29 AM   #13
snobrdrdan
snobrdrdan's Avatar
2009
Just did the fiance's new '07 Ion 3 QC this morning.....took 15 minutes....
PICS:
2009 VW GTI
Old 07-01-2007, 03:43 PM   #14
SaturnSdn
SaturnSdn will become famous soon enoughSaturnSdn will become famous soon enough
SaturnSdn's Avatar
2007 ION-3 Sedan
2007 ION-3 Sedan
I'll keep what I have.....
http://s198.photobucket.com/albums/a...rent=MODS4.jpg
Add to SaturnSdn's Reputation
Rate the quality of this post and help SaturnSdn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SaturnSdn is offline   Reply With Quote
Old 07-02-2007, 11:24 AM   #15
NoRemorse
NoRemorse is on a distinguished road
NoRemorse's Avatar
Originally Posted by SaturnSdn View Post
I think the 'no attenna' look is much cleaner, and the signal strength is not affected at all as far as I can tell (I do a lot of driving, and i lose the channels in the same places before and after)
Add to NoRemorse's Reputation
Rate the quality of this post and help NoRemorse reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
NoRemorse is offline   Reply With Quote
Old 07-02-2007, 12:34 PM   #16
SaturnSdn
SaturnSdn's Avatar
2007 ION-3 Sedan
2007 ION-3 Sedan
I didn't say that anyone lost reception..........and still I'd not bother doing that mod myself for the time spent as I just don't drive down the road looking at other peoples car antennas
Old 07-02-2007, 01:54 PM   #17
migs1974
migs1974's Avatar
2003 ION-2 Sedan
i did mine a month and a half ago and i definitely lost reception. luckily i dont listen to the radio much but there's is definitely more static than before. still listenable though.
poop
Old 07-02-2007, 05:25 PM   #18
SaturnSdn
SaturnSdn's Avatar
2007 ION-3 Sedan
2007 ION-3 Sedan
PS: and I never said I didn't like the look of the antenna gone......I did however say what I said.
Old 07-02-2007, 06:33 PM   #19
snobrdrdan
snobrdrdan's Avatar
2009
I tried the little rubber antenna and it looked "okay" but then it cracked anyways
I just hate how the stock one ruins the "side profile" of the car....it's too tall and doesn't flow with the curves of the car
I never lost reception....sounds perfect still
Plus less drag without the antenna there/whipping around in the wind
2009 VW GTI
Old 07-02-2007, 06:41 PM   #20
SaturnSdn
SaturnSdn's Avatar
2007 ION-3 Sedan
2007 ION-3 Sedan
^5 on the drag DAN........................LOL. I have a few rubber ones around here, two of which were on my 2001 Saturn SL2's. No cracking or pealing. Clean them up and the look like new.
antenna mod Jsolts S-Series Mods 19 01-26-2007 12:31 AM
antenna mod quiksc2 S-Series Mods 11 10-12-2006 11:58 AM
Antenna mod mziol S-Series Mods 16 09-09-2006 09:10 PM
Mod, please delete. paxman356 L-Series General 0 10-21-2005 09:16 PM
Can't Delete Pictures In My Gallery... Bertillion Community Center 1 02-18-2005 09:11 PM
