Old 10-02-2012, 02:48 PM   #1
ninetynineSC2
ninetynineSC2 has a spectacular aura aboutninetynineSC2 has a spectacular aura aboutninetynineSC2 has a spectacular aura about
ninetynineSC2's Avatar
1999 SC2
Default Rough idle after flooring it? 1999 SC2
I gunned my car when I was pulling across the road into a friends driveway and noticed it idled rough (Felt like it was misfiring) for a minute or so after that. After I drove it not even a mile it was running just fine. Why would it have done that? ECTS is brass btw.
Add to ninetynineSC2's Reputation
Rate the quality of this post and help ninetynineSC2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ninetynineSC2 is offline   Reply With Quote
Old 10-02-2012, 02:57 PM   #2
colonelhogan44
colonelhogan44 is just really nicecolonelhogan44 is just really nicecolonelhogan44 is just really nicecolonelhogan44 is just really nicecolonelhogan44 is just really nice
colonelhogan44's Avatar
Default Re: Rough idle after flooring it? 1999 SC2
Sounds like you may have burned an exhaust valve.
How many miles on the car, and how many miles are on the fuel filter?
MechE - I make things!
EGR ADAPTERS AVAILABLE! $30 "reverse" $40 standard
1998 SL2 (gone, never forgotten)
2005 Volvo S40 T5 AWD
1987 Mercedes 300D
1993 Tracker 4x4
1996 Tracker 4x4
Add to colonelhogan44's Reputation
Rate the quality of this post and help colonelhogan44 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 10-02-2012, 03:04 PM   #3
ninetynineSC2
1999 SC2
Just about to hit 131,000 and not sure about the filter. It's the first time it's idled like that after flooring it. I've had to do that before pulling into traffic on the highway and it's never idled rough after that. Like I said it only idled rough for maybe 30 seconds to a minute then it was fine. Wouldn't a burned exhaust valve make it run rough all the time?
Old 10-02-2012, 03:41 PM   #4
mansaturn
mansaturn is on a distinguished road
nope, just at idle. unless you've got more serious stuff going on. but meantime, check the normal tune-up items: wires and non-platinum plugs to start
Add to mansaturn's Reputation
Rate the quality of this post and help mansaturn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mansaturn is offline   Reply With Quote
Old 10-03-2012, 10:51 AM   #5
ninetynineSC2
1999 SC2
Yeah, I was going to check the plugs and wires before winter. The plugs only have about 10,000 on them though but they ARE the cheap copper ones so I don't know how long they'd last. Not sure about the wires, haven't replaced them yet.
Old 10-03-2012, 01:57 PM   #6
ninetynineSC2
1999 SC2
Would there be a way to test for a burned valve without having to tear the motor apart?
Old 10-03-2012, 04:57 PM   #7
colonelhogan44
So it idles fine now?
1987 Mercedes 300D
1993 Tracker 4x4
1996 Tracker 4x4
Old 10-03-2012, 10:07 PM   #8
magtec
magtec will become famous soon enough
1995 SW2
compression test.
Add to magtec's Reputation
Rate the quality of this post and help magtec reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
magtec is offline   Reply With Quote
Old 10-04-2012, 09:34 AM   #9
ninetynineSC2
1999 SC2
Yeah, its running like new, like it normally does.
Old 10-04-2012, 12:42 PM   #10
colonelhogan44
Then I wouldn't worry about it. Just replace the fuel filter so you don't burn a valve next time.
1987 Mercedes 300D
1993 Tracker 4x4
1996 Tracker 4x4
Old 10-04-2012, 01:48 PM   #11
ninetynineSC2
1999 SC2
Yeah, she probably needs a new filter anyway.
Old 10-04-2012, 09:03 PM   #12
magtec
1995 SW2
if you're replacing the fuel filter make sure you go with OEM or NAPA/WIX. this is one thing you do NOT want to skimp on.
Old 10-05-2012, 09:30 AM   #13
ninetynineSC2
1999 SC2
Will do.
1999 Saturn SC1 rough idle/vibration ifried85 S-Series Tech 14 07-26-2018 10:35 AM
1999 SL2 Rough Idle When Cold todd8 S-Series Tech 4 03-05-2012 08:45 AM
1999 Saturn SL-2 Running rough and stalls at idle. Trequilo S-Series Tech 1 10-07-2011 04:53 PM
97 SC2 5 speed - Rough Idle & Rough Start Jyounya S-Series General 2 07-05-2011 03:58 PM
rough idle, rough sluggish pickup, 97slw smiles233 S-Series General 7 10-14-2005 04:28 PM
