Old 12-23-2010, 11:46 PM   #1
megaman8x
megaman8x is on a distinguished road
Default problem with back wheels
A month or ago my tire went flat and so i put on one of my donuts from my parts car. So a few weeks ago i started hearing screeching noises from the wheel where the spare tire was on, I thought it was the spare going out and since i was gonna replace it soon I didn't pay it any attention, last week it started getting worse where it would make a loud screeching, scratching sound when i would break so I thought this donut was really about to go at any second, so today i tried to get one more trip on the donut when I started hearing the noise and noticed and then i started t to wooble and the donut busted luckily a police officer was there and told he had seen it and gave me a ride back home where i borrowed a friends donut. I make my way back to the car and and change the tire and I start to hear the screeching again and this time it is accompanied with the smell of rubber which eventually led to that donut being busted so i had to slowly scrap along to reach my back lawn and i noticed that my breaks weren't pumping all the way (they did a little but not fully) and i looked into the brake fluid tank and see that its completely empty (which i don't know if its related seeing I knocked it a few times taking the air intake off to clean the egr valve a few days earlier)
my question is could this be the wheel(weel boot, shoes) itself causing the screeching or was it just two bad donuts? thanks.
megaman8x is offline   Reply With Quote
Old 12-24-2010, 02:17 AM   #2
radi
radi is on a distinguished road
Default Re: problem with back wheels
Sounds like you have a bigger problem than just a bad donut spare.
I'm gonna guess a bad wheel bearing/hub?
If your master cylinder is dry, you no doubt have air in the brake system now, which would account for the bad brake pedal. You'll have to refill that and bleed the air out....before you drive it anywhere else.
Do you see any brake fluid leaks?
radi is offline   Reply With Quote
Old 12-24-2010, 06:31 AM   #3
There's probably a pond in at least one drum from a leaking wheel cylinder.
Might have locked the shoes to the drum & that's whats killing your donuts.
Old 12-24-2010, 01:52 PM   #4
megaman8x
If that is the case (hopefully seeing its the cheapest) how would i get the break drum off to check the cylinder if the shoes are pressed against it?
also when i was tightening the lugs when the tire would move a little bit it would make a scraping sound not sure if that helps narrow down the problem
Old 12-29-2010, 09:51 AM   #5
72gssaturn
72gssaturn will become famous soon enough72gssaturn will become famous soon enough
72gssaturn's Avatar
2008 Astra XR
the scraping sound indicates that the drum & brakeshoe(s) is/are making contact. there should be a slot with either a metal or rubber plug in the back of the brake back plate that u can remove. using a flat screwdriver, u can turn the adjusting wheel whichever direction to loosen/back off the brakeshoes.
Gerry
72 Buick GS red
2008 Astra XR black 3dr
99 SL1
72gssaturn is offline   Reply With Quote
Old 12-31-2010, 04:04 PM   #6
megaman8x
OK I've got updates, turns out the car does not have drums but rotors and pads and had a close relative who is a mechanic look at it, pretty much told me the rotor was done, it had been eating through (these were all the original pads and rotors that came with the car when bought it) that the caliper had locked into place and that it might have "frozen" which means it had to be replaced.
So he said the way to check if its still good was to unscrew the caliper bolts and use a screw driver to try to pry out the caliper but after the pain of trying to get the bolts off the lower one broke in half which means I have to get a new caliber mount if I cant get it out, we were able to get the rest of the parts off the pads were pretty much trash and after taking off the caliber he was able to compress back into the piston by winding it back in and says it should still be good seeing that it didn't have any leaks.(not sure about this does anyone know)
my question is that I have a parts car Ive been using to fix this one up and could I use one of the caliber mounts off one of the front wheels and use it or do i have to get a new mount specifically for the rear caliper?
Old 01-01-2011, 06:42 AM   #7
Rear caliper is significantly smaller then the front, need a mount specific to the rear.
Old 01-02-2011, 06:55 PM   #8
megaman8x
Well Ive been looking online and cannot find any caliper brackets for the rear only the fronts and don't want to pay for a whole caliper so does anyone know where to find them online or somewhere cheap?
Old 01-02-2011, 07:47 PM   #9
A-1 CARDONE Part # 141152 $24 (rear left)
A-1 CARDONE Part # 141151 $24 (rear right)
Both on rockauto.com, well for '91-'98 I guess. Pretty sure '99+ never came from the factory with rear calipers.
Old 01-02-2011, 09:25 PM   #10
Cane3D
Cane3D is on a distinguished road
I didnt know that saturns in general ever came with rear calipers, my '00 sc2 def only has front calipers, but it would have been nice to have rear ones as well..
Do you think he could kinda DIY convert front calipers to replace the rear ones.. rotors and all, or would that be too much work, cause i guess his car is already set up for it, so maybe use (if the same size) same front calipers on the back for replacement..
This is more of a question/guess, just wondering myself and trying to help out!
Cane3D is offline   Reply With Quote
Old 01-03-2011, 12:30 AM   #11
PurdueGuy
PurdueGuy's Avatar
1999 SC1
No, the front brakes are completely different from the rears, and nothing substantial will swap.
Also, it's not a good idea to be driving around on donut tires for weeks, they're meant to get you home after a flat, maybe get you by for a day or two at low speeds, they're not meant for regular use.
SaturnSeries.net owner
Old 01-03-2011, 06:32 AM   #12
Technically yes. It'd require taking the front brackets & calipers from the parts car & putting 'em on. Even then I think the mounting bolts on the rear hub are closer together then the fronts. And he wouldn't have a parking brake. And since the front calipers hold more fluid then the rears it'd reduce the braking ability of the rear even more (not good).
I'll see if I've got the rear brackets at my current house, as it's been a long time since I looked at 'em. I do know that when put side by side the brackets are vastly different in size.
Old 01-10-2011, 12:01 AM   #13
megaman8x
Well since i will be replacing one rotor I decided to just replace both rear rotors and brake pads, I going with the wearever rotors from AAP I wish i could get the wragners but It doesn't say if they fit the rear.
My question is which kind of pads should I get; semi metallic or ceramic? from what Ive read ceramics eat through the rotors and are only compatible with certain cars, is that true?
Old 01-10-2011, 08:46 AM   #14
72gssaturn
72gssaturn's Avatar
2008 Astra XR
use semi-metallic, front & rear.
Gerry
72 Buick GS red
99 SL1
Old 02-01-2011, 10:48 PM   #15
megaman8x
I finally have the parts to rebuild it but I don't know to use brake grease or silicon on the pins/pads I was told not to use grease cause it could dry up and seize and silicon wont, which one should I use ?
alloy wheels in back,steel in front? bigbfarm S-Series Tech 14 08-11-2009 10:10 AM
Only have 2 Alloy wheels - front or back? Saturn #4 L-Series General 3 02-23-2009 11:17 AM
FS: Borla cat-back, header, wheels, wires, fpr Lane Classifieds 1 05-01-2004 01:43 PM
finally put summer wheels back on rascon11 Ion General 2 03-27-2004 10:28 PM
Saturn wants wheels back!! help me!! QC_Nate Ion General 30 05-24-2003 07:11 PM
