Old 07-04-2016, 11:53 PM   #1
HHx66
HHx66 is on a distinguished road
Default 1993 Saturn SC2 Ignition 2 30A blowing?
I have a 1993 Saturn SC2, the 30A Ignition 2 fuse under the hood blew once about a year ago, I replaced it, no problem for a year (this was most likely an OEM fuse in it, so I didn't think much about it) after that about a week ago it blew again, I replaced it, all was well, I was planning on taking it to a more mechanically inclined friend/mechanic that I know to look it over but didn't really get a chance to, tonight I was stopped at a stop sign the car instantly cut off, would not start, checked over a few things and went to fuses, found it blown, dropped in a replacement I had on hand, car started for a second and blew instantly, tried 2 more and still had the same issue, at that point I left it where it was at a friends house and got a ride home, but now I am trying to figure out what could be causing this? Aside from this issue the car is fine, running fine, no issues. I just replaced the starter on it about 4-5 months ago as well as the battery, and didn't have any issues since until tonight.
I didn't have a chance to check over any other fuses as it was late, didn't have much for lights.
Add to HHx66's Reputation
Rate the quality of this post and help HHx66 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
HHx66 is offline   Reply With Quote
Old 07-05-2016, 12:18 AM   #2
billr
billr is a glorious beacon of lightbillr is a glorious beacon of lightbillr is a glorious beacon of lightbillr is a glorious beacon of lightbillr is a glorious beacon of light
Default Re: 1993 Saturn SC2 Ignition 2 30A blowing?
A short in the wiring to the ICM or a short in the ICM would be my guess. Disconnect the two connectors at the ICM and see if a new fuse blows. If not, then re-connect the harness and see if the fuse does blow. If it does, then the ICM is probably bad. If it doesn't, then maybe you just "fixed" a short in the wiring by moving it in the disconnect/re-connect process; indicating a good visual check of the wiring harness is due.
Add to billr's Reputation
Old 07-05-2016, 02:39 AM   #3
There is no 30A maxifuse in a 93 marked as IGN 2. Check the nomenclature carefully as IGN-2 is not listed in the FSM as a 30A maxifuse located in the UHJB(engine fuse box). There is no0 IGN-2 fuse in either fuse box of any size or rating.
By any chance are you stating the physical location from top to bottom position in the UHJB?
Old 07-05-2016, 01:46 PM   #4
HHx66
It's marked in the under the hood fuse compartment as IGN 2 4th fuse down,30A not sure what else. Haven't had a chance to check it yet today as i am at work, but plan on going to it today with a mechanic friend of mine when I get out of work.
Old 07-05-2016, 02:05 PM   #5
The Factory Service Manual begs to differ as well as the 91-94 data book. According to what I have here in front of me that is the IGN-4 maxifuse. This fuse feeds the following minifuses: IGN-1, TURN, B/U LP, EGR, DIS, PCM I, INJ, Radio, Wiper, AirBag.
The most likely point of the problem will be the multifunction switch associated with power to the wipers as the other continuous loads along with a ground on the wiper will open the 30A fuse in most cases. It could also be a failing ignition switch, not the key lock but the actual switch.
Manuals have been known to have random errors but if it is the 4th one down then it is IGN-4 based on the drawings and opening of that fuse promptly shuts the car off.
The 92-93 cars have identical wiring and the 91 and 94 are slightly different so using the correct drawings is critical to locating this.
Saturn SL2 keeps blowing ignition fuse. mike2002 General Saturn Discussion 3 03-28-2015 07:35 PM
SL2 park fuse keeps blowing, and blowing Herbivore S-Series Tech 13 02-23-2015 12:52 PM
1993 saturn sw2 twin cam ignition satillacwagswag S-Series Tech 2 12-10-2013 12:42 AM
Saturn Ion 2 (2007) Ignition Lock or ignition Switch Manual Transmission infinitezero Ion Tech 5 11-25-2011 05:47 PM
1993 Sl2 Ignition Key Stuck johnny_boyyy S-Series Tech 4 09-26-2005 04:33 PM
