Old 01-16-2013, 07:36 PM   #1
mystic54
mystic54 is on a distinguished road
Default '98 SC2 - High Engine Coolant Temp and Low Coolant Level Warning Light
Started seeing the High Engine Coolant Temperature/Automatic Transaxle Fluid Temperature and Low Coolant Level Warning light flash on and then off when driving. The coolant does indeed seem low.
In the six years I've owned this car, I'm not sure if I've ever had to add/do anything with the coolant. I'm hoping DexCool was used before and the coolant in there is an organish/yellow (which seems right), but I'm still a bit worried. Do I just hope for the best and just add more DexCool and water (50/50) in?
Add to mystic54's Reputation
Rate the quality of this post and help mystic54 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mystic54 is offline   Reply With Quote
Old 01-16-2013, 07:51 PM   #2
Default Re: '98 SC2 - High Engine Coolant Temp and Low Coolant Level Warning Light
If you have no idea what is in there now then add 100% Universal antifreeze, not the 50/50 junk. Also have no idea of the concentration. The correct approach would be a drain and complete flush followed with a refill with a full gallon of 100% universal antifreeze and top off with distilled water. The service life of DexCool is 5 years on initial fill and 3 years on a refill.
Old 01-17-2013, 11:15 AM   #3
And if your coolant keeps dropping, check for leaks. Usual suspects are the driver side radiator end tank (black plastic tank tends to bulge and split) and the water pump (passenger side - this is harder to see, you 'll need a flashlight and also look for coolant on the floor)
You also see an occasional bad cap on the reservoir
edit: actually, check for leaks and do what OldNuc suggested, as your antifreeze sounds like it is pretty old.
Old 01-17-2013, 09:29 PM   #4
bobyjones
bobyjones is on a distinguished road
you might want to get a new radiator while your at it, ive had two dex cars that i swapped a new radiator in the same time i swapped out dex cool, cause you're gonna have all that crap in your system still, radiators are cheaper than a new car, youll have to replace it anyhow, trust me they go at 150k-220k, my 3 last saturns all new radiators
especially if its been neglected like that chance are the radiators already on its way out, might as well do a heater core while your at it too, they only 15$ at a junk yard almost new
just go all out and rebuild your entire system its wicked easy, even the water pump is fairly easy, that way you know youll never have a problem again
or not
Add to bobyjones's Reputation
Rate the quality of this post and help bobyjones reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bobyjones is offline   Reply With Quote
High engine Temp./transaxle coolant light flashed. Commando44 S-Series General 11 02-15-2008 01:27 AM
High temp / low coolant warning light when rainy SC_SL2 S-Series General 14 11-06-2007 03:29 PM
Coolant Temp & Level Light Flashing NJ-SL S-Series General 7 04-09-2004 07:56 PM
Intermitant coolant temp. and coolant level light? speedy45 Miscellaneous Tech 1 11-01-2001 08:40 PM
Coolant Temp/Level light flashing Rodney S-Series Tech 8 03-30-2001 02:21 AM
