Old 05-28-2012, 04:06 PM   #1
jonolsonroll200
jonolsonroll200 is on a distinguished road
Default 2004 3.5l vue - PARK fuse blowing
Hello,
I have a 2004 saturn vue, 3.5L FWD.
The park fuse keeps blowing intermittently. Last time I had this problem it was a bad GM radio, that I replaced with an after market radio. I thought perhaps the issue was the after market radio so I removed it. Still pops.
Sometimes it will burst upon turning on the car in the dark, sometimes it will burst hours of driving later.
I've checked some of the bulbs (tail lights in particular) and did not see anything obvious.
I do not think I have a trailer hitch.
One thing I did notice on my car is that there was some front end damage to the metal bar that runs along in front of the radiator. The radiator is bowed inwards a bit, along with the metal bar and the radiator fan. I'm wondering if the PARK fuse wiring runs around that area? I can't tell by just staring at the electrical diagram.
Any ideas?
Add to jonolsonroll200's Reputation
Rate the quality of this post and help jonolsonroll200 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jonolsonroll200 is offline   Reply With Quote
Old 05-28-2012, 06:42 PM   #2
far2grumpy
far2grumpy's Avatar
Default Re: 2004 3.5l vue - PARK fuse blowing
Originally Posted by jonolsonroll200 View Post
Hello,
Any ideas?
You could have a pinched wire - see thumbnails below - one is wiring diagram and two others depict cable harness routing for front of VUE.
It does appear the harness with right side PARK/MARKER wiring (index 18 and 19) passes through the damaged area.
The front end stuff - bumper covers, grill, lights, etc. - is simple to remove if you want to take a closer look at the harness. Repost or send PM and I'll email the needed extracts.
If you want to check bulbs first - there are 10 PARK/MARKER bulbs - plus the radio lighting - fed by PARK fuse so you should remove each bulb to inspect bulb and socket.
I don't spend much time on forum but answer private messages (PM email my phone). Include email address if you need pdf extracts. Don't use visitor message - I forget to check those.
Ign 3 Fuse keeps blowing...Help! 04 ION QC2 S-Series Tech 19 05-12-2015 02:40 PM
Park Lamp mini fuse keeps blowing ar04 L-Series Tech 2 08-07-2009 10:59 AM
Park Fuse keeps blowing Whiteshadow651 S-Series General 7 02-13-2009 12:28 PM
"Park" (instrument panel) fuse keeps blowing OhioSaturnGuy S-Series Tech 3 07-15-2006 03:42 PM
fuse blowing` garyh_rosies S-Series Tech 3 12-24-2003 06:36 PM
