Old 12-09-2010, 08:32 PM   #1
Bob Panczak
Bob Panczak has a spectacular aura aboutBob Panczak has a spectacular aura about
Question 2000 LS2 Thermostat Issue What temp should coolant be at normal operating temp
I have a 2002 LS2 L81 3 Liter V-6 where the heat is rather tepid when the temperature falls below 25. I reverse flushed the cooling system this fall by attaching a flushing tee on the heater inlet hose and replaced the coolant with Dex-Cool. When I flushed the system, the water that came out was clear with no rust. No change in heat. Today I hooked up a scan tool and drove around to note the coolant temp. It ranged from 165 at start-up after sitting for about a half an hour to 187 after letting ldle for a few minutes. at cruise the temp dropped at as low as 175 and climbed back up to 185. I suspect that the thermostat is bad as with a 195 Degree stat the temp should be around 195 to 210 as the manual states. Had this problem last year as well. Any ideas or should figure I'm going to be taking on this five hour job. I have not had any codes set for low coolant temperature.
Thanks,
Bob
Add to Bob Panczak's Reputation
Rate the quality of this post and help Bob Panczak reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Bob Panczak is offline   Reply With Quote
Old 12-09-2010, 09:03 PM   #2
Default Re: 2000 LS2 Thermostat Issue What temp should coolant be at normal operating temp
Replace the thermostat. I did mine and posted some tips and pics. Others have too. A major pita but it must be done. I didn't have my dial thermometer reading temps before replacement but it reads off the scale now; the dial stops at 140F with the needle going another 90 degrees past - maybe 185F-190F when my auto climate control lowers the blower speed to idle? To paraphrase Paris Hilton a little, "My car's HOT!"
Old 12-10-2010, 06:40 PM   #3
Bob Panczak
Thanks, YOu have pretty much confirmed my feelings. I will replace the stat.
Bob
Old 12-14-2010, 01:49 AM   #4
halmiles
halmiles is on a distinguished road
1999 SW2
Thanks,
Bob
You are going to have to bite the bullet and replace the thermostat. Get a top brand like a Stant 195 degree. It won't open until you reach its rated temperature and will keep it in that range,
Add to halmiles's Reputation
Rate the quality of this post and help halmiles reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
halmiles is offline   Reply With Quote
Aura XE 3.5 - What is the normal operating temp? usa4624 Aura General 22 04-22-2009 02:50 PM
2002 SL2 Normal Operating Temp?? s31248 S-Series Tech 1 03-27-2009 05:39 PM
Coolant Temp Below Thermostat Regulating Temp runninpapa L-Series General 2 01-30-2008 11:27 PM
what is the normal operating temp for a 1997 sc2 desaturn S-Series Tech 18 06-06-2006 09:46 PM
2002 V6 Vue: P0128 code: "Engine coolant temp below thermostat temp" coolgreany Vue Tech 12 02-06-2006 07:03 AM
