Old 02-07-2009, 09:25 AM   #1
Astrafirstsatur
Astrafirstsatur is on a distinguished road
2008 Astra XE
Roll Eyes Information Center (DIC) Engine temp or Coolant Temp ?
I held the settings button until I heard the chime/beep, then push BC to scroll through items displayed in the engineering/diagnostic mode.
I found an item labelled LCD . Does anyone know what that is ?
I want to be able to look at the coolant temperature or at the engine temperature.
Thank you
Add to Astrafirstsatur's Reputation
Rate the quality of this post and help Astrafirstsatur reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Astrafirstsatur is offline   Reply With Quote
Old 02-07-2009, 03:56 PM   #2
DEPHELAN
DEPHELAN is on a distinguished road
DEPHELAN's Avatar
Default Re: Information Center (DIC) Engine temp or Coolant Temp ?
Yeah I found that weird that there is no way to check the engine temp. Then again I might just not be looking in the right place for it.
2008 3dr XR 5sp
Add to DEPHELAN's Reputation
Rate the quality of this post and help DEPHELAN reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
DEPHELAN is offline   Reply With Quote
Old 02-07-2009, 04:35 PM   #3
Astrafirstsatur
2008 Astra XE
Happy Re: Information Center (DIC) Engine temp or Coolant Temp ?
LCD IS NOT THE COOLANT TEMP : However I still do not know what it is.
There is a screen with a "V" on the bottom left and a "T" on the far right bottom of the display.
When the engine is warmed, the temp seems to stay in a band from 90 degrees C to 93
The "V" is speed or velocity , and I'm not sure what the units are. When you look at this, when the car is parked, it appears that the temperature is labelled "OT", when in fact that really means that V : 0 (zero speed)
Old 02-08-2009, 03:35 PM   #4
Astrafirstsatur
2008 Astra XE
Cool Re: Information Center (DIC) Engine temp or Coolant Temp ?
VOILA - some snapshots
Old 02-08-2009, 11:46 PM   #5
GoodMoGo
GoodMoGo is on a distinguished road
2008 Astra XR
My guess is that the V stands for Voltage and the pic on the left shows there is no alternator activity, while the one on the right displays 13.5 volts (which is the actual voltage I get on a voltmeter when the car is running.
2008 Astra XR - 5-door Manual
1974 Alfa-Romeo Spider Veloce
2009 Kawasaki Versys
Add to GoodMoGo's Reputation
Rate the quality of this post and help GoodMoGo reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
GoodMoGo is offline   Reply With Quote
Old 02-09-2009, 10:17 AM   #6
marx404
marx404 will become famous soon enough
marx404's Avatar
2008 Astra XE
the first screen V = velocity which should equal KPH (kilometers per hour). Great for verifying your speedomoter accuracy (expect it to be off by as much as 3mph, thats normal for most german cars).
marx404
Saturn lives on.
2007 ION.3
2008 Astra XE
2004 L300.1
Add to marx404's Reputation
Rate the quality of this post and help marx404 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
marx404 is offline   Reply With Quote
Old 02-14-2009, 05:06 AM   #7
Layoira
Layoira is on a distinguished road
Layoira's Avatar
2008 Astra XR
I have a link to post for this to explain the screens. Im too tired to think off hand what each is for, and its much easier to post the link. Will add it as soon as I find it. Its for the GID (Uplevel display) But is similar functions for the BID (Base level display)
Here you go:
http://translate.google.com/translat...u/test_bk.html
Its been google translated so a few errors but you get the idea. This is for the GID Screen. The BID Screen (Base level one) Is similar, just some things you just dont see as much info if I remember correctly. I took pics of my BID test mode before changing my screen to my GID so I will take a look at them later after Ive slept and can think lol and will compare
Add to Layoira's Reputation
Rate the quality of this post and help Layoira reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Layoira is offline   Reply With Quote
Old 02-14-2009, 11:48 AM   #8
marx404
marx404's Avatar
2008 Astra XE
Layoira, Thank You!!!! very cool!
marx404
Saturn lives on.
2007 ION.3
2008 Astra XE
2004 L300.1
Old 02-14-2009, 01:29 PM   #9
Layoira
Layoira's Avatar
2008 Astra XR
You're welcome Comes in handy!
Old 02-15-2009, 11:29 PM   #10
wangfei
wangfei is on a distinguished road
Default 1111111111111111111
11111111111111111111111111111111111111111
111111111111111111111111111111111111111111111 1111111111111
Add to wangfei's Reputation
Rate the quality of this post and help wangfei reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
wangfei is offline   Reply With Quote
Old 02-16-2009, 09:10 AM   #11
Robor007
Robor007 is on a distinguished road
2008 Astra XR
Default Re: 1111111111111111111
I don't get it...
2008 Astra XR3 door 5sp - Silver Sand with premium trim, 18" rims, and advanced audio. (new owner as of 12/15)
Add to Robor007's Reputation
Rate the quality of this post and help Robor007 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Robor007 is offline   Reply With Quote
Engine coolant temp sensor? sleepersatty99 S-Series Tech 8 06-06-2009 09:06 PM
Air temp and Coolant temp sensors the same? JonP S-Series Tech 15 03-28-2009 07:44 AM
Coolant Temp Below Thermostat Regulating Temp runninpapa L-Series General 2 01-30-2008 11:27 PM
Flashing coolant temp/trans temp/low coolant lights DanB98TJ S-Series Tech 5 07-18-2007 02:11 PM
2002 V6 Vue: P0128 code: "Engine coolant temp below thermostat temp" coolgreany Vue Tech 12 02-06-2006 07:03 AM
