Old 01-27-2008, 04:23 PM   #1
runninpapa
runninpapa is on a distinguished road
Default Coolant Temp Below Thermostat Regulating Temp
My Daughter has a 2002 L300 with 66000 miles, the car has never left So. Cal. . This winter we had a cold spell. The Sevice Engine Soon light came on, I checked the code and needed to replace the Engine Coolant Temp. sensor. The Sevice Engine light came on about six weeks later with the same code. Second time I replace the ECT sensor. A few days ago the Service Engine light came back on. This time I get a P0128 code telling me the Coolant Temp Below Thermostat Regulanting Temp. . Is it time for a new Thermostat or is it just the strange weather we are having in So. Cal. ?
Add to runninpapa's Reputation
Rate the quality of this post and help runninpapa reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
runninpapa is offline   Reply With Quote
Old 01-28-2008, 04:41 AM   #2
IsaySaturn
IsaySaturn is on a distinguished road
IsaySaturn's Avatar
Default Re: Coolant Temp Below Thermostat Regulating Temp
Change the thermostat. Problem solved. It is not weather related.
The temp sensor you replaced never goes bad on your model.
Changing the thermostat yourself on your model is quite a job.
Good Luck!
"Do you see my point of VUE?"
03 L200 all options - 01 LW200 (RIP)
06 Nissan Armada SE 4x2
07 Toyota Fj Cruiser 4x4
Add to IsaySaturn's Reputation
Rate the quality of this post and help IsaySaturn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
IsaySaturn is offline   Reply With Quote
Old 01-30-2008, 11:27 PM   #3
runninpapa
IsaySaturn,
Thanks for the info. The thermostat can't be any harder than doing a tune-up on my PT Crusier. I've done all the work on it, from lowering it, to a few engine mods.
Thanks again,
runninpapa
Air temp and Coolant temp sensors the same? JonP S-Series Tech 15 03-28-2009 07:44 AM
Information Center (DIC) Engine temp or Coolant Temp ? Astrafirstsatur Astra Tech 10 02-16-2009 09:10 AM
95 SC2 Coolant, thermostat, temp. senders Alutious S-Series Tech 12 02-18-2008 11:37 AM
Flashing coolant temp/trans temp/low coolant lights DanB98TJ S-Series Tech 5 07-18-2007 02:11 PM
2002 V6 Vue: P0128 code: "Engine coolant temp below thermostat temp" coolgreany Vue Tech 12 02-06-2006 07:03 AM
