Old 07-18-2007, 12:41 PM   #1
DanB98TJ
DanB98TJ is on a distinguished road
1997 SW1
Mad Flashing coolant temp/trans temp/low coolant lights
Within a block of leaving work yesterday, the engine coolant temp/trans fluid temp/low coolant lights started flashing. I stopped and checked the fluid level and it was fine. Temperature gauge was less than 1/2 way, and since I had only driven a block there is no way the trans fluid was too hot.
After doing a search this morning, I pulled the reservoir and cleaned it out. I also replaced the ECTS and trans temp sensors. All the connectors and wiring look fine. The lights are still flashing.....
In an attempt to try to rule out the coolant level sensor in the reservoir, I made a jumper...lights are still flashing.
Now what?????
1997 Saturn SW1, auto trans, 121k miles
Add to DanB98TJ's Reputation
Rate the quality of this post and help DanB98TJ reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
DanB98TJ is offline   Reply With Quote
Old 07-18-2007, 01:20 PM   #2
Zvolen
Zvolen is on a distinguished road
1998 SL1
Default Re: Flashing coolant temp/trans temp/low coolant lights
It may be simple, but did you reset the light?
Add to Zvolen's Reputation
Rate the quality of this post and help Zvolen reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Zvolen is offline   Reply With Quote
Old 07-18-2007, 01:34 PM   #3
DanB98TJ
1997 SW1
How do you reset the light? Disconnect the battery?
Old 07-18-2007, 01:46 PM   #4
BarnOwl
BarnOwl's Avatar
There's no reset for that light. Flashing when the coolant is okay means there's a problem with the sensor in the reservior. I'm not sure why your jumper isn't working but, that is where the problem lies.
Add to BarnOwl's Reputation
Old 07-18-2007, 01:55 PM   #5
DanB98TJ
1997 SW1
Thanks - I'll redo the jumper just in case it's not making good contact. If that doesn't work I guess I'll just keep driving it....
Old 07-18-2007, 02:11 PM   #6
DanB98TJ
1997 SW1
Well, the jumper was making good contact, so I did what I should have done first: checked the backup light fuse. It was blown. Replaced the trans and ECTS sensors, wasted nearly three hours, all for a ten-cent part.
If your coolant/trans/low coolant light starts to blink, do two things first: check the coolant level, and check the $#%& backup light fuse.
Low coolant and temp warning light flashing briefly when cold outside shallow S-Series General 24 08-26-2014 04:41 AM
Aww damn, Coolant temp flashing? wy2sl0 S-Series Tech 5 07-15-2009 03:32 PM
Coolant/temp light flashing Violet S-Series Tech 7 03-08-2009 12:13 AM
low coolant/temp light flashing CBrown L-Series General 1 06-28-2006 05:30 PM
Coolant Temp/Level light flashing Rodney S-Series Tech 8 03-30-2001 02:21 AM
