Old 06-09-2007, 05:10 PM   #1
opus
opus is on a distinguished road
Dizzy Strut mount problems 00 SW2
Hey all,
I had my struts replaced about four months ago. About four weeks after the replacement I began getting a grinding noise when turning the steering wheel. I took it in, he took the strut assembly and mount apart and said he lubed the mount bushings. The sound went away and the steering feel was great. Then about three weeks ago, when the weather began to get really hot, I started noticing the grinding/moaning sound again. I waited to see if it would go away, but no luck. I took it back to the mechanic, he was very pleasant and said he would put a different strut mount on, at no charge. He called back and said that he was able to get the sound out of the right strut, but it is still in the left strut, and he is stumped, he says he has torn it apart four or five times. I was wondering if anyone here on the board could lend any guidance as far as where he should look for the culprit. Thanks in advance.
Todd
Add to opus's Reputation
Rate the quality of this post and help opus reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
opus is offline   Reply With Quote
Old 06-09-2007, 11:30 PM   #2
eRic 02sc2
eRic 02sc2's Avatar
Default Re: Strut mount problems 00 SW2
If you're hearing noise after replacing both strut mounts with Saturn OE mounts, then have the wheel bearings and cv joints checked. They make noises too when they go bad.
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
Old 06-10-2007, 02:49 PM   #3
opus
I don't believe they were Saturn OE mounts. I know he put Monroe Struts in, I had the same struts put in my 99 SL2 and they worked fine. But I am not sure the mounts were OE, as a matter of fact I am sure they were not OE. Would this cause a known problem?
Old 06-11-2007, 06:30 AM   #4
BarnOwl
BarnOwl's Avatar
I've not seen any postings that indicate a problem with aftermarket strut mounts. I agree with eRic 02sc2, if you can't find the problem with the strut mounts, it's probably not the strut mounts. Time to look elsewhere.
Add to BarnOwl's Reputation
Old 06-11-2007, 11:12 AM   #5
opus
Barnowl and Eric,
Thank you very much for the feedback and info. It makes life a little easier. I will tell my mechanic to start investigating other possibilities.
Opus
Old 06-11-2007, 01:00 PM   #6
Wait, wait -- when are you hearing the noise? If it's while you're just cruising down the road, or hitting bumps, it's probably NOT the strut mounts in the first place. If it's while you're steering, whether the car is moving or not, it most likely IS the strut mounts. If you hear it when the car is not moving, forget the wheel bearings. CV joint might grind when standing still, but it's more likely going to make noise when moving slow, and more likely gonna be a click-click.
I did my front struts a couple months ago -- KYB GR-2's, Gabriel top mounts and the OEM springs and OEM spring-top rubber thingy. The d@mn spring-top rubber part rubs on the bottom of the mount. When I'm steering the car at low speed, or stopped, the rubbing makes them moan like Paris Hilt... er... well, they grind/moan. I couldn't figure out a way out of it. It must be something to do with the mongrel assemblage of parts. OEM strut mounts would probably have been a better choice, but hindsight is 20/20. Perhaps one clear day when I have spare time (huh-huh), I'll disassemble one side and slice a bit of rubber off the top of one of the spring-toppers, to see if that creates clearance between it and the mount. Figure I'll wait 'til I'm ready to spring for another alignment anyway, after a year or so, or if I hit a nasty-@ss hole.
Add to madpogue's Reputation
Old 06-11-2007, 03:31 PM   #7
richpin06
richpin06 is a jewel in the roughrichpin06 is a jewel in the roughrichpin06 is a jewel in the roughrichpin06 is a jewel in the rough
richpin06's Avatar
She sure didn't go to the Meg Ryan school of moaning.
http://www.youtube.com/watch?v=25Xzx-5vdaA
Add to richpin06's Reputation
Rate the quality of this post and help richpin06 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 06-13-2007, 12:21 AM   #8
opus
Saturn OEM mounts fixed the problem. The problem there is that the mount comes with everything and the two of them ended up running $300.00. I am so sick of this finicky Saturn OEM stuff. My mechanic said from now on he would just leave the OEM stuff in place when replacing Saturn struts. He just bought a 97 Saturn for himself, so lucky me got to be a guinea pig .
Strut Mount sattyman2008 S-Series Tech 1 10-13-2008 10:21 PM
Strut mount melt down MeMongo66 S-Series Tech 1 03-18-2008 08:56 PM
Dealer replaced strut, strut mount, and strut bearing tomcatt1 Vue General 17 10-03-2007 04:53 PM
Strut mount phoenixsc2 S-Series Tech 2 01-28-2007 01:13 AM
upper strut mount problems?? satrunracer Miscellaneous Tech 1 07-21-2001 02:59 PM
