Old 10-28-2018, 05:17 PM   #1
bigredcar
bigredcar is on a distinguished road
Dizzy Crazy problem. wont start unless above 60F
hello. have been on this forum for years but just registered.
saturn ion 2.2 L ecotec 2004 manual.
the issue: can't post youtube link aparently. will post in comments
wont start unless its above 60 degrees outside.
it starts all summer but in fall it does not start. unless:
> its sunny then i can get it to start if i open the hood and the sun shines on the engine for 5 minutes.
i live in portland oregon so no more sun until spring.
i have been dealing with this for 2 years. in that time i have replaced:
ignition switch. starter. battery.
i am doing all of these repairs myself.
when it does not start in cold i get a p0606 code, which goes away in the summer.
I know it is not the passlock issue. as i have already fixed that. in all my research i have never heard of an engine sounding like mine when it tries to start. kind of like half cranking or something.
please help if you can, i have no idea what to do next.
Add to bigredcar's Reputation
Rate the quality of this post and help bigredcar reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bigredcar is offline   Reply With Quote
Old 10-28-2018, 05:19 PM   #2
bigredcar
Default Re: Crazy problem. wont start unless above 60F
ok i guess i can't even post the video in the comments. that sucks
Old 10-28-2018, 06:29 PM   #3
A few years ago spammers began infiltrating Saturnfans with Charlie the admin adding tweaks. One was restricting new members from posting links until 15 are made. You can always type the address here as text instead of a quick link address. The same for any other address until your minimum posts are exceeded to demonstrate you're going to around for awhile.
P0606 is about the engine computer. This diagnostic applies to internal microprocessor integrity conditions within the engine control module (ECM). This diagnostic also addresses if the ECM is not programmed. More below.
Car info? Mileage, maintenance done, parts replaced, mods?
Old 10-28-2018, 07:17 PM   #4
bigredcar
Tanks for the reply.
milage: 140K
Parts replaced: battery, starter, ignition switch
Maintenance: changed coolant and oil.
no mods
I still cant post with text link, sorry :/
if you search youtube for "Saturn ion weird starting issue in cold." it should be the first video showing the engine bay area.
Old 10-28-2018, 08:51 PM   #5
What's the date when posting your video? Or type the complete http address manually so anyone can copy and have google/bing/whatever search engine find it and go to the youtube video.
Were spark plugs ever replaced? At what mileage intervals? Ever check fuel pressure (borrowed Autozone f/p gauge?)?
Old 11-17-2018, 03:39 AM   #6
bigredcar
I keep trying to type it in, just keeps flagging it.
I have TRIED replacing the sp but i might have done something wrong and it wouldn't start, so had to put the old ones back in, so those have probably been in there since 2010 haha.
The only way i have tested the pressure was just opening the valve and pressing on it with a paper towel, a strong spray came out.
As a work around to all of this i have thought of installing some kind of block heater, which would just kind of go around the true issue.
Or an easier idea i had was to just put a heat lamp up to the engine for an hour or so every time i wanted to drive it, will update if this works haha.
thanks for the replies! and sorry for the delays, got busy with work.
Old 11-17-2018, 08:44 AM   #7
Is this the video? https://youtu.be/ZdOW2OuK-AM
Old 12-26-2018, 12:44 AM   #8
bigredcar
Originally Posted by fdryer View Post
Is this the video? []
Yes!!!! That's it
It's in such a sad state right now nice it's been so long since i've driven it.
I hope there's something i can do
Old 12-26-2018, 04:46 AM   #9
Remove spark plugs, ignition system fuse, fuel pump fuse or pump relay (to prevent pump operation). Are plugs wet with fuel? Will the engine turnover easily with plugs removed?
Old 12-27-2018, 11:29 AM   #10
atikovi
Sounds like the starter is disengaging as soon as you turn the key. Bad solenoid?
Add to atikovi's Reputation
Old 01-30-2019, 10:34 PM   #11
bigredcar
I thought the Solenoid was part of the starter, which i replaced
Old 01-30-2019, 10:36 PM   #12
bigredcar
Hey thanks for this! I'll try and report what happens, haha sounds interesting
2005 Saturn Vue turns over, but wont start + IC wont work BlueVueMN Vue Tech 2 06-10-2015 05:50 PM
Wont start problem, not finding the exact situation in searches trouttrooper S-Series Tech 3 08-18-2013 01:45 PM
98 SL2 - Odd problem, wont start papayamon2 S-Series Tech 4 05-03-2009 06:54 PM
Car wont start! possible cold weather problem? northviper S-Series Tech 10 01-04-2008 10:57 AM
Key code problem, car wont start???? and where do i get a short shifter? ub3rn00ber Ion General 8 10-12-2006 08:28 PM
