Old 09-05-2006, 06:43 PM   #1
turbobuick33
turbobuick33 is on a distinguished road
turbobuick33's Avatar
1992 SL2
Default Question about replacing the lower engine and trans mount
When replacing the lower engine mounts and the trans mount, does the top engine mount on the pass side have to come off?
Add to turbobuick33's Reputation
Rate the quality of this post and help turbobuick33 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
turbobuick33 is offline   Reply With Quote
Old 09-05-2006, 06:51 PM   #2
andy_95sl2
andy_95sl2 is on a distinguished road
andy_95sl2's Avatar
Default Re: Question about replacing the lower engine and trans mount
no, you can access all of it from the top, or wheel well. The lower transmission mount is easy enough.. Just remove the driver wheel and splash guard, and jack up the transmission side an inch or two to remove stress on the mount. Remove the bolts and it will come loose. Jack up the tranny another few inches to let the mount come out of the subframe. For the top tranny mount, remove the battery and tray, and the intake tubing and its right there. Lower engine dogbone is easy enough too, but will give more clearance with the TAM unbolted temporarily.
2004 Jeep Wrangler Rubicon -> daily & toy =)
2009 BMW 128i -> sold
2003 VW GTI 1.8T -> wrecked
1998 Saturn SL2 -> parted out
1995 Saturn SL2 -> sold
Add to andy_95sl2's Reputation
Rate the quality of this post and help andy_95sl2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
andy_95sl2 is offline   Reply With Quote
Old 09-05-2006, 10:08 PM   #3
When you're finished, don't forget to make this final adjustment (from our How-To Library).
Add to madpogue's Reputation
Old 09-06-2006, 07:41 PM   #4
turbobuick33
1992 SL2
Another question I have..The 2 wish bone mounts, one on the driverside by the crank pully and the other one on the passenger side, are they same size and be the same part #?
Old 09-06-2006, 07:57 PM   #5
project92SC2
project92SC2 is on a distinguished road
1992 SC2
1991 SL2
Yes. They are the same.
Add to project92SC2's Reputation
Rate the quality of this post and help project92SC2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
project92SC2 is offline   Reply With Quote
Old 09-06-2006, 07:58 PM   #6
elko51racer
elko51racer is on a distinguished road
elko51racer's Avatar
no i work for the dealer.. it can be done from the bottom, its pretty simple, there iwll be two bolts into the trans and 1 bolt into the cradle
Add to elko51racer's Reputation
Rate the quality of this post and help elko51racer reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
elko51racer is offline   Reply With Quote
Replacing The Lower Tranmission Mount BarnOwl How-To Library 12 03-10-2012 09:16 PM
lower trans mount bdobraj S-Series General 3 12-11-2009 09:50 AM
Dogbones and lower engine mount question... pogster S-Series General 15 10-22-2008 05:06 PM
Lower (trans) Mount mg95SL2 S-Series Tech 9 06-17-2008 11:10 PM
Replacing the Lower Transmission Mount Luke How-To Library 4 02-01-2005 06:27 PM
