Old 04-12-2007, 09:15 PM   #21
Default Re: Steam Cleaning Your Engine Cylinders
"You are in a helicopter." (Bonus points for anyone who knows the reference...)
The above post is all true, but irrelevant to this thread. This thread is not about "pouring water into the cylinders" (which, of course, would be impossible in a running engine anyway). That's not what happens when you draw Seafoam or anything water-based into the intake manifold. When you do, and it's drawn into the combustion chambers, it BOILS in the heat of the engine (this is why you START the procedure with a HOT engine), and enters as STEAM, which, given its pressure, blasts the coked-up deposits loose. As for removing lubrication, even if it happened, each cylinder wall would be re-lubricated on the very next up-stroke of the piston.
Add to madpogue's Reputation
Old 04-20-2007, 05:51 AM   #22
Jim Dunlop
Jim Dunlop is on a distinguished road
Jim Dunlop's Avatar
2002 SL
1998 SL
Putting water down the cylinders is a bad idea, as it would also remove lubricant from the cylinder walls.
If you're worried about water de-lubricating your engine, you shouldn't run gasoline through your engine.
Octane is a much better solvent for motor oil than water is. Also, water is a combustion product of octane...so there is plenty of steam in your engine anyhow. This procedure just adds more "punch"...and it's not like you're doing it all day long. The volume expansion ratio of liquid water to steam is around 1,500(!), whereas the steam produced by octane combustion should already be in the vapor phase.
I haven't been able to find the Seafoam in CA either. It may be that certain parts of the state have it, I don't know.
Watch out for those Eco-Terrorists...I think you are less likely to get bumped off by a hit job if you use water to clean your engine instead of a solvent-based cleaner. I used to work in the aerosol industry so I know what it's like to be the victim of chemophobic hate speech.
I, for one, am going to give this steam procedure a try!
2002 SL 1.9L SOHC 5-spd mods:
-Custom HAI
-K&N Airbox Filter
-Custom Air Dam
-PCV Catch Can
-Drilled & slotted rotors
-14x6 König Incident's, Yoko AVID's
-Grille Block (aluminum)
SCS! DD.
Add to Jim Dunlop's Reputation
Rate the quality of this post and help Jim Dunlop reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Jim Dunlop is offline   Reply With Quote
Old 07-09-2007, 07:52 PM   #23
TwinRevver
TwinRevver is on a distinguished road
Of all the posts here are correct to a degree. First of all, when u pour or spray in a hose sucking air, it "atomized" with the air to create tiny droplets. Heat from heated intake mani converts to steam in the process of entering the combustion area.
A 1987 VW Jetta with more than 350,00 miles head gasket finally gave away at cylinder #1. It still ran albeit rough chugging. Upon teardown of the head shown #1 cylinder the SHINIEST of all. Other three were very dull and had some light carbonizations.
So, steam chugging does work wonders. Think about the Scuzii(sp) little red teapot steamer cleaning ur kitchen and clothes stains.
Add to TwinRevver's Reputation
Rate the quality of this post and help TwinRevver reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
TwinRevver is offline   Reply With Quote
Old 02-23-2008, 04:32 PM   #24
Drdla99SL2
Drdla99SL2 is on a distinguished road
You guys are absolutely crazy. Putting water into the combustion chamber? Most people would do anything to AVOID getting water in the combustion chamber. Firstly, when performing this procedure you are putting air into the engine that is dirty and not going through an airfilter. Secondly, putting water in you engine will cause you bigger problems than anything. When you spray the water in the TB it goes into the cylinder which is superhot creating steam on the induction stroke. The water evaporates turning into steam taking up more volume. So when the piston comes up again to TDC guess what? You are not only compressing the AF mixture but also this steam creating a higher compression which could potentially f%*& things up inside your engine. Instead of this use a product DESIGNED to clean your engine(such as seafoam or forte).
Anyways goodluck!
Add to Drdla99SL2's Reputation
Rate the quality of this post and help Drdla99SL2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Drdla99SL2 is offline   Reply With Quote
Old 02-24-2008, 05:40 PM   #25
Telyx
Telyx is on a distinguished road
2002 SL
Anyways goodluck!
"Absolutely crazy?" Sure, and I'd believe any of them. They know what happens when you put water in an engine, and that's why they recommend small amounts, not enough to damage anything. And the air won't be "dirty" enough to worry about if you don't do this during a sandstorm or near a dirt road.
Add to Telyx's Reputation
Rate the quality of this post and help Telyx reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Telyx is offline   Reply With Quote
Old 02-24-2008, 06:59 PM   #26
Drdla99SL2
All I'm saying is there are product DESIGNED to clean your engine much better than a so called "steam clean". The cost roughly $10 and work very well. Last time I checked at my dealership we never offered a steam clean service
Old 06-27-2014, 04:27 AM   #27
pappy_mcfae
pappy_mcfae is on a distinguished road
Anyone who has ever had to change a head gasket because coolant was leaking into the combustion chamber knows full well just how good of a job high pressure steam does in cleaning the top of the piston, and the bottom of the valves.
The twist I always use with this process is to atomize 50/50 mix of coolant and water. Using a vacuum T with one port open allows air into the mix. That helps insure you won't suffer the woes of hydrolock with a running engine. It fogs bugs big time, too.
Cheers,
Pappy
Add to pappy_mcfae's Reputation
Rate the quality of this post and help pappy_mcfae reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
pappy_mcfae is offline   Reply With Quote
Steam Cleaning Qustion mgordon1100 S-Series Tech 9 07-15-2007 04:47 PM
Engine Cleaning StormTrackVUE Vue General 4 07-10-2006 07:41 PM
Cleaning the Engine impaler Vue General 24 05-25-2006 04:14 PM
water - Steam cleaning a 2.2L engine bgsneeze Ion General 5 12-02-2005 01:01 AM
Engine seems to be running on 3 cylinders Mike H S-Series Tech 3 05-04-2005 09:22 PM
