Old 03-20-2006, 12:48 PM   #1
440sixPack
440sixPack is on a distinguished road
Wrench Steam Cleaning Your Engine Cylinders
Usually done with engines >100k miles on them.
I saw some questions about this, so here's how you do it. As always, be careful and don't hold me responsible if you mess up your car.
First, this is easier with someone helping you. Go buy a bottle of spring water (20 oz is what I use) or if you don't want to spend any money, get water from a tap that has little or no additives (chlorine, salt, etc...).
1. Start your car and let it warm up.
2. Remove the air ducts from throttle body (air cleaner off carburated cars).
3. Increase idle of engine slowly till ~3500 rpms. You can use your free hand or have someone help you.
4. Keep the engine idle high and slowly poor water in the throttle body. If you hear the engine bogging down, slow down or stop pooring the water. It should take 40 seconds to empty the bottle.
5. Make sure you keep the engine idle high the entire time!!!
6. After the bottle is empty, keep engine idle high for another minute or so.
7. Drive car around for 10 minutes preferable at speeds > 45 mph (so engine heats up to burn any remaining water from oil).
Yes it works and will clean your cylinders very well. It's safe as long as you pay attention to how your engine is behaving and keep the idle up. If you do stall your car, don't bother trying to start it again. Just pull the plugs, allow the car to turn over a couple of times, dry plugs (or get new ones) and put them back in. Don't use ether or other combustibles to try to start it. Start it normal. I've cleaned 7 engines like this without any problems. Because you are adding water to the engine, this is best done a couple of days before you plan to change the oil.
If you have any questions, I'll try my best to answer them.
Add to 440sixPack's Reputation
Rate the quality of this post and help 440sixPack reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
440sixPack is offline   Reply With Quote
Old 03-22-2006, 10:15 PM   #2
binaryh4x
binaryh4x is on a distinguished road
binaryh4x's Avatar
Default Re: Steam Cleaning Your Engine Cylinders
Spring water contains minerals still. Distilled water is all I know of for "pure" water.
combustion creates water as a bi-product anyway, why is this any better?
1995 Saturn SC2: Elizibeth
Add to binaryh4x's Reputation
Rate the quality of this post and help binaryh4x reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
binaryh4x is offline   Reply With Quote
Old 03-23-2006, 12:05 AM   #3
eRic 02sc2
eRic 02sc2's Avatar
I've done this but I used GM Top Engine Cleaner instead of water. after emptying the can and the 15 minute soak and restart, it fogged the mosquitoes
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
Old 03-26-2006, 12:18 PM   #4
djcommie
djcommie is on a distinguished road
I do the same, but use SeaFoam, which is a mixture of pale oil, a light solvent, and isopropyl alcohol. I suck it in through the brake booster line, or whatever is sucked into all cylinders.
Add to djcommie's Reputation
Rate the quality of this post and help djcommie reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
djcommie is offline   Reply With Quote
Old 09-16-2006, 12:06 AM   #5
bobbyrae
bobbyrae has a spectacular aura aboutbobbyrae has a spectacular aura about
1993 SL2
You guys are correct that Seafoam and GM Top engine cleaner probably will work better, however, in California, those two products are banned for environmental reasons and so all we are left with is the steam cleaning approach.
Bobby Rae
Alameda, CA
1993 SL2 A/T, 80k miles, 22/33/43 mpg
1982 Accord 5-speed, 303k miles, 23/32/40 mpg
Add to bobbyrae's Reputation
Rate the quality of this post and help bobbyrae reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bobbyrae is offline   Reply With Quote
Old 11-28-2006, 04:31 AM   #6
RangerRuss
RangerRuss is on a distinguished road
2003 VUE 2.2L
I can still purchase Seafoam in California and have done so recently. I do not understand why it is supposedly "banned"?
Russ
1993 SL-1 - R.I.P.
2003 VUE
2002 Ford Ranger
2003 Buick Regal
Add to RangerRuss's Reputation
Rate the quality of this post and help RangerRuss reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
RangerRuss is offline   Reply With Quote
Old 11-28-2006, 12:26 PM   #7
L200Pilot
L200Pilot is on a distinguished road
L200Pilot's Avatar
2008 Astra XR
2002 L-Series 2.2L Sedan
Russ
Ditto, here. It was on the shelf when I went to Autozone yesterday. I used Seafoam when I did the OP's engine cleaning. Didn't harm the engine, but don't think it really had any effect either way. But eRic is right, no more mosquitos!
The family:
1993 SL2: 051,000 mi (!)
1996 SL2: 260,000 mi (sold)
2001 SL2: 98,000 mi
2002 L200: 215,000 mi
2006 VUE: 50,000 mi (sold)
2007 Ranger: 40,000 mi
2008 Astra: 161,000 mi
Add to L200Pilot's Reputation
Rate the quality of this post and help L200Pilot reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
L200Pilot is offline   Reply With Quote
Old 12-02-2006, 07:03 PM   #8
Ritz
Ritz's Avatar
I can't imagine it being banned. Are you certain? It's just a mixture of naptha, isopropyl alcohol and a wee bit of light base oil. None of those items are banned individually, so I find it difficult to believe that the mixture is banned.
I also can't imagine that helping your engine ingest water will do anything positive. Water is a very poor solvent for the crap that's adhered to your runners/valves/combustion chamber.
Cheers,
Add to Ritz's Reputation
Rate the quality of this post and help Ritz reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 12-03-2006, 12:03 AM   #9
True about water being a lousy solvent, but there's also the physical action. Whatever you pour in (unless it's something combustible), it boils on the combustion stroke, and it's the force of the steam that does some of the work of knocking the stuff loose.
Add to madpogue's Reputation
Old 12-03-2006, 11:18 AM   #10
Ritz
Ritz's Avatar
Even steam is a pretty poor solvent for hydrocarbon deposits. This "steam cleaning" thing is most likely a myth. The chemistry just doesn't work.
Cheers,
Old 12-03-2006, 08:54 PM   #11
HeroHog
HeroHog is on a distinguished road
HeroHog's Avatar
2007 ION-3 Quad Coupe
Water, misted / poured in a SMALL stream into an induction system WILL remove carbon from the cylinder heads. The physics / chemistry of it I can't explain, but it DOES work. The thing that can cause an issue with this is if a large carbon deposit / flake gets hung in a valve. Rare but it does (rarely) happen. Back when they 1st started using water injection in the old piston engine fighter planes, the mechanics noticed how much less carbon deposits there were in the water injected engines VS the non-injected ones.
Some of the old mechanics used to pour ATF or Marvel Mystery Oil down the carb to remove carbon build-up.
Hero Hog
07 Ion QC 3 2.2L
Add to HeroHog's Reputation
Rate the quality of this post and help HeroHog reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
HeroHog is offline   Reply With Quote
Old 12-04-2006, 08:00 PM   #12
Ever seen a side of a building being steam-blasted clean? There's no "chemistry" involved; it's all physical action. Yeah, something with solvent properties is better, but the physical action of the steam will remove something (albeit not much).
Old 12-04-2006, 10:23 PM   #13
Ritz
Ritz's Avatar
Sure, steam under very high pressure directed at a surface can clean it. That's not what you're getting when you dribble water into your intake while the motor is running.
Cheers,
Old 02-13-2007, 12:09 AM   #14
Cat Fuzz
Cat Fuzz is on a distinguished road
Cat Fuzz's Avatar
1992 SL2
If you've ever seen the top of a piston after a blown head gasket, you'll agree that this process works. Steam cleaning makes combustion chambers squeaky clean.
03 GMC Envoy XL
99 Isuzu Rodeo V-6, 4WD, Rebuilt 3.2L with 3.5L internals
63 Mercury Comet Convertible
Add to Cat Fuzz's Reputation
Rate the quality of this post and help Cat Fuzz reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Cat Fuzz is offline   Reply With Quote
Old 02-13-2007, 11:08 AM   #15
jeep4523
jeep4523 is on a distinguished road
Cheers,
Worked great in WWII bombers. And it works great in boosted vehicles.
Generally, folks will be running water injection and upon teardown find pretty damn clean combustion chambers.
I don't know if such a small period of time will do the trick, but I do know continous use does the trick.
Democracy is two wolves and a sheep voting on what to have for dinner. Liberty is a well armed sheep contesting that decision.
Add to jeep4523's Reputation
Rate the quality of this post and help jeep4523 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jeep4523 is offline   Reply With Quote
Old 02-14-2007, 12:17 PM   #16
Ritz
Ritz's Avatar
'cept water injection wasn't used for cleaning in the bombers or the turbo vehicles. It was used to keep combustion chamber temperatures down and prevent detonation. You're talking about a completely different thing.
But if you want to try the "steam cleaning" trick and then tear off the head(s) and let us know how well it works, I look forward to hearing about your progress. In the absence of any facts to the contrary, I'm going to consider this pure myth.
Cheers,
Old 02-14-2007, 05:48 PM   #17
HeroHog
HeroHog's Avatar
The whole point is: water injected in the intake of a running engine WILL remove carbon deposits from the combustion chambers.
Hero Hog
07 Ion QC 3 2.2L
Old 04-06-2007, 05:47 AM   #18
bobbyrae
1993 SL2
Cheers,
I have this confirmed through a GM parts guy as well as a Local auto parts guy. I really don't know why, I suppose it would be because of the smoke, which is a pollutant. I haven't been able to find the Seafoam in CA either. It may be that certain parts of the state have it, I don't know.
As far as the water goes, it turns into steam on combustion, creating more pressure and turbulence in there. I've talked to auto mechanics who use this approach. Have you ever heard someone saying that they open their car up once a week to burn out the carbon? Adding the water gives a similar effect without the high RPM's. Of course, the chemicals work even better.
Bobby Rae
Alameda, CA
Old 04-06-2007, 07:51 AM   #19
Gerry Proctor
2008 Astra XR
2008 SKY Red Line
Water in the combustion chamber does work very well. First learned of this in the early 70s, when combustion chamber deposits were a much bigger issue than they are today. One of the simple diagnostics for coolant intrusion into the combustion chamber is to pull a plug. The clean plug is the one that's getting coolant. Though, I would go with the GM Top cleaner as a more effective treatement since water does nothing for deposits on the back-side of the intake valve.
Old 04-11-2007, 10:33 PM   #20
RealHippy
RealHippy is on a distinguished road
I have to side with Ritz on this.(did I just say that ) Putting water down the cylinders is a bad idea, as it would also remove lubricant from the cylinder walls. Water would have little effect on carbon deposits. The carbon is cooked on to the combustion chamber, water would have little effect on it.
Try it and then pull the head off the car and tell me it worked.... It won't.
I have rebuilt enough engines to know this.
Add to RealHippy's Reputation
Rate the quality of this post and help RealHippy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
RealHippy is offline   Reply With Quote
Steam Cleaning Qustion mgordon1100 S-Series Tech 9 07-15-2007 04:47 PM
Engine Cleaning StormTrackVUE Vue General 4 07-10-2006 07:41 PM
Cleaning the Engine impaler Vue General 24 05-25-2006 04:14 PM
water - Steam cleaning a 2.2L engine bgsneeze Ion General 5 12-02-2005 01:01 AM
Engine seems to be running on 3 cylinders Mike H S-Series Tech 3 05-04-2005 09:22 PM
