Old 12-17-2003, 01:46 AM   #1
amazinghl
Wrench Changing the Oil Without Jack or Ramp
*Put some dirty clothes or clothes you don't care on.
First, put the key in and turn the wheel all the way to the left.
put an oil pan under your car.
Then, put use a 14mm wrench and take the drain plug off then let it drain. Turn the drain plug clock-wise to loosen it *you're upside down, remember?*
00 Insight 72mpg
Add to amazinghl's Reputation
amazinghl is offline
Old 12-17-2003, 01:49 AM   #2
amazinghl
Default
Now, take 4 of those plastic screw off *so that you can push the spash guard out of the way* by using a flat head screw driver to take of the center portion of the screw FIRST.
That white thing is your oil filter.
I use this oil filter wrench to get my filter off and then let the more oil drain out. *take the filter off SLOWLY to make a lesser oil mess! *Couter-clockwise to get the oil filter off.
Don't forget to put a layer of oil around that rubber seal!
Then, put the drain plug and oil filter back in and pour the oil. And clean up all the oil mess you made. After that, turn on the car for 10 seconds to check for leaks, then you're done.
*tips, have lots of old newspaper with you
00 Insight 72mpg
Old 12-17-2003, 01:51 AM   #3
WhtCastle
WhtCastle is on a distinguished road
WhtCastle's Avatar
Default
You can also put your car up on a curb.
Add to WhtCastle's Reputation
Rate the quality of this post and help WhtCastle reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
WhtCastle is offline
Old 12-17-2003, 05:52 PM   #4
eljefino
eljefino's Avatar
1995 SW1
Default
My filter is black.
Add to eljefino's Reputation
eljefino is offline
Old 12-17-2003, 11:39 PM   #5
Hiddenlites
Hiddenlites is on a distinguished road
Hiddenlites's Avatar
1993 SC2
Default
Well, mine is blue. Those oil filters come in all sorts of pertty colors. I've seen yellow, orange, red, oh who cares!
1993 Saturn SC2 75k
2004 Chevy Silverado Z71
2008 Saturn VUE Redline 175k sold 7/8/16
2013 Honda Accord Coupe
2016 GMC Acadia
Add to Hiddenlites's Reputation
Rate the quality of this post and help Hiddenlites reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Hiddenlites is offline
Old 12-20-2003, 03:39 PM   #6
SLeepr
SLeepr is on a distinguished road
SLeepr's Avatar
Default
Splash guards? What splash guards! heehee
Nice job, Amazinghl
Add to SLeepr's Reputation
Rate the quality of this post and help SLeepr reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SLeepr is offline
Old 12-20-2003, 09:37 PM   #7
Jammer
Jammer is on a distinguished road
Jammer's Avatar
2003 ION-3 Sedan
Default
Mine is red. Good job on the post-reply. Curbs and low sewer grates are a good bet, just watch not to drain the oil into the grate.
Add to Jammer's Reputation
Rate the quality of this post and help Jammer reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Jammer is offline
Old 01-01-2004, 09:54 PM   #8
David 93 SL2m
David 93 SL2m's Avatar
2004 VUE 2.2L
2007 ION-3 Sedan
Default
I cut my splash guard(s) for the front right wheel well so that it is easier and faster to get to the oil filter! I'll try to take a picture of that area on my SL2 at the next oil change.
If your S-Series has ABS then be careful around that sensor wire when moving the splash shields! :o:
Current
∙ 2004 VUE 124K
∙ 2007 ION3 112K
Past
∙ 1993 SL2 212K
∙ 1993 SC2 140K
∙ 1996 SC2 157K
∙ 1996 SC2 126K
∙ 2001 SC2, 145K
∙ 2002 L200 20K
∙ 2002 SL1 129K
David 93 SL2m is offline
Old 01-23-2004, 11:07 AM   #9
eRic 02sc2
eRic 02sc2's Avatar
Default
my sc2 sits too low to the ground to do this without rhino ramps.
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
eRic 02sc2 is offline
Old 01-28-2004, 11:47 AM   #10
amazinghl
Default
Please don't use fram oil filter.
It has lesser filter area, glued cardborad base, problematic rubber anti-drainback valve seals, plastic bypass valves, etc.
http://minimopar.knizefamily.net/oi...study.html#fram
00 Insight 72mpg
Old 01-29-2004, 11:36 AM   #11
eRic 02sc2
eRic 02sc2's Avatar
Default
hmm...the saturn oil filter says "filtration by fram" on it.
eRic 02sc2
Old 04-01-2004, 05:24 PM   #12
jasonpopnc
jasonpopnc is on a distinguished road
Default
I know of a guy in Chapel Hill, NC that pulls his van over the storm sewer grate in front of his house and empties his oil in the storm sewer!
Add to jasonpopnc's Reputation
Rate the quality of this post and help jasonpopnc reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jasonpopnc is offline
Old 04-01-2004, 05:41 PM   #13
eljefino
eljefino's Avatar
1995 SW1
Default
I hope that moron loses his drain plug down the grate and gets his vehicle impounded when he's walking to buy a new one.
eljefino is offline
Old 04-01-2004, 09:26 PM   #14
David 93 SL2m
2004 VUE 2.2L
2007 ION-3 Sedan
Mad
Call the police the next time you see this idiot draining his oil like that!
Current
∙ 2004 VUE 124K
∙ 2007 ION3 112K
Past
∙ 1993 SL2 212K
∙ 1993 SC2 140K
∙ 1996 SC2 157K
∙ 1996 SC2 126K
∙ 2001 SC2, 145K
∙ 2002 L200 20K
∙ 2002 SL1 129K
Old 04-02-2004, 11:23 AM   #15
Luke
Luke's Avatar
Default
Fm David
Yeah, I second that......
Add to Luke's Reputation
Luke is offline
Old 05-04-2004, 05:55 PM   #16
thewretched
thewretched is on a distinguished road
thewretched's Avatar
Default
hey david, did you ever take a picture of that cut guard?
I put my car up on ramps today and it scared me to go under it
Add to thewretched's Reputation
Rate the quality of this post and help thewretched reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
thewretched is offline
Old 05-04-2004, 08:17 PM   #17
David 93 SL2m
2004 VUE 2.2L
2007 ION-3 Sedan
Dizzy
Arg! I forgot about that promise and just changed the oil in my 1993 SL2 last weekend! I'll leave work early tomorrow, take a picture or two, and post them in this thread.
Make sure that the rear wheels are chocked. I find it scary just driving up the ramps! Probably I would be less nervous if my car had an automatic transmission.
Current
∙ 2004 VUE 124K
∙ 2007 ION3 112K
Past
∙ 1993 SL2 212K
∙ 1993 SC2 140K
∙ 1996 SC2 157K
∙ 1996 SC2 126K
∙ 2001 SC2, 145K
∙ 2002 L200 20K
∙ 2002 SL1 129K
Old 05-04-2004, 08:53 PM   #18
thewretched
Default
yeah, see, I have an auto, and I sorta drove OVER the ramps the first time I tried, and they got stuck under my car and it was not pleasant. I managed to get one out from under the car using brute force (since im so manly) and then I put the free ramp under the side that was still stuck and drove up it to free up the other one.
blah blah blah it sucked.
but anyway, I got it right the second time only to find that I had no chokes and didn't really have any wood readily available, so I just took a few peeks under the car and then backed it back down.
...maybe next time will be more successful.
Old 08-16-2004, 06:26 AM   #19
plum_sc2
plum_sc2 is on a distinguished road
1993 SC2
Default
i still wanna know why the damn oil pan was not galvanized??????? mine's about ready to rust thru!!!!!!!
1993 SC2 - 168,000 miles
2003 Vue - 104,000 miles
Add to plum_sc2's Reputation
Rate the quality of this post and help plum_sc2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
plum_sc2 is offline
Old 08-16-2004, 11:09 AM   #20
Luke
Luke's Avatar
Default
Fm David
I'll second that......for that type of conduct clearly indicates that the person has absoutely not consideration for others, other than him/her self. It is a very revealing trait. It also reveals traits of insensitivity, diception, as well as possessing no creditility. Beware of this guy -- his actions reveal alot.......
** One VERY HAPPY person, with my manual radiator fan switch, Thanks to Wolf's guidance ** 95 SL2, 386,986 Miles..... 40.35 MPG (10 Tank Full Avg) as of Aug 16, '04. Quaker State 10w-40 Oil, using 1 qt / 1,000 miles
Luke is offline
Changing Motor Mount, Jack Question Kal S-Series Tech 8 07-08-2008 12:24 PM
Where do I put the floor jack when changing a tranny mount? fixit4mywife S-Series Tech 3 06-04-2008 05:53 AM
Oil change w/o ramps or jack 01SL1SATURN S-Series General 42 01-15-2008 04:05 PM
Homemade Ramp Pit Tercero S-Series General 16 10-24-2007 11:59 AM
Changing floor jack hydraulic oil? bigbird Miscellaneous Tech 2 09-17-2004 04:45 PM
