Old 09-15-2005, 12:36 PM   #101
peppermrj
peppermrj is on a distinguished road
peppermrj's Avatar
Default Re: Cleaning the Combustion Camber Using Water?
Has anyone heard of using this procedure with transmission fluid?
Add to peppermrj's Reputation
Rate the quality of this post and help peppermrj reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
peppermrj is offline
Old 09-15-2005, 01:38 PM   #102
SylenThunder
SylenThunder is on a distinguished road
SylenThunder's Avatar
2003 VUE 2.2L
2004 VUE 2.2L
no, but I can't imagine why you would want to pour oil into your intake.
Add to SylenThunder's Reputation
Rate the quality of this post and help SylenThunder reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SylenThunder is offline
Old 09-15-2005, 01:46 PM   #103
BarnOwl
BarnOwl's Avatar
In the bad old days of carberators, people would do it to clean their valves. I haven't heard of anyone doing it in years.
Add to BarnOwl's Reputation
BarnOwl is offline
Old 09-16-2005, 02:01 AM   #104
sierrap615
sierrap615's Avatar
i have heard of people using a mixture of ATF and water(mostly water), but in which case, the ATF is used more for a lubracent then a cleaner. i think i will stick with water, and in real bad cases, GM Top engine cleaner
Formerly - Saturn of Downers Grove Parts Department
Current - Castle Chevy in Villa Park Parts Department
EPA 608 Certification
EPA 609 Certification
sierrap615 is offline
Old 10-16-2005, 12:39 PM   #105
tgparker
tgparker is on a distinguished road
tgparker's Avatar
1997 SW1
Dizzy Re: Cleaning the Combustion Camber Using Water?
This sounds like a really simple good idea. It's low tech and back-yard mechanic which I like.
I'm a total newbie so I need like really idiot simple dummy instructions.
Intake tube on the throttle. Which intake tube and where is it located, and how do I indentify it. What parts do I take off first to access the trottle body and this tube?
Are there any good pics of this procedure anywhere that I can look at please?
Also what lever do I pull, push, to keep the engine idling at 2000 rpm while I'm puring water down the intake tube?
Thanking you in advance,
Tony
Add to tgparker's Reputation
Rate the quality of this post and help tgparker reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
tgparker is offline
Old 10-16-2005, 01:00 PM   #106
tgparker
tgparker's Avatar
1997 SW1
Great idea! I'm a newbie and I have no idea what "the vacuum line from your brake booster", where it is located or what parts I might have to remove to get to it. Do you have any idiot simple instructions with even some pic to illustrate where I can even find this part. I tried locating what your talking about in both Chilton and Haynes and they were next to useless. Is there any on-line source where I might some kind of diagrams that might help?
Tony
Originally Posted by TIMSPEED
Harry,
A product called "SeaFoam" has the same effect, only greater cleaning power, and it's safer than water. I'd try it, it helped my friend pass smog.
It's easy to use, you just pull the vacuum line from your brake booster and stick it in the can and then start the car. It'll either suck the bottle dry and keep running, or the car will stall. If it sucks the can dry and keeps running, turn it off and let it sit for about 45 minutes. (If the car stalls, start it up again, until it sucks out all the seafoam.) After the 45 minutes, start the car. (you may have to keep the car running with a little throttle.)
Warning: The car is gonna smoke like CRAZY!! This is the crud burning off, this is good. I just did to my cousin's car and I plan to do it to my SC2. You MIIIIGHT have to buy new spark plugs after using SeaFoam, because SOMETIMES it fouls them...But it's really good to use.
tgparker is offline
Old 10-17-2005, 08:42 PM   #107
sierrap615
sierrap615's Avatar
the "tube" is the air induction tube, the big 2.5-3" wide black from the air filter box to the throttle body. remove the tube to access to throttle body(screw driver req.)
you manually control the throttle by rotating the semi-circle plate on the throttle body connecting the throttle cable.
DO NOT USE THE BRAKE BOOSTER HOSE!!!! its to large and will flow to much, ether manually pour the water/cleaner in via the throttle body or use the small vacuum line for the fuel pressure regular(91-97 saturns only)
Old 10-18-2005, 11:16 AM   #108
SylenThunder
2003 VUE 2.2L
2004 VUE 2.2L
unless, of course, you have a newer saturn with the electronically controlled throttle body.... then it take two ppl.
Old 10-18-2005, 08:49 PM   #109
tgparker
tgparker's Avatar
1997 SW1
Thank you so much for the info BTW where is the "small vacum line fuel pressure regular" what does it look like and how can I identify it please?
Thanks in advance...
Remember I'm a total newbie...
Tony
tgparker is offline
Old 10-19-2005, 05:00 PM   #110
David 93 SL2m
David 93 SL2m's Avatar
2004 VUE 2.2L
2007 ION-3 Sedan
Idea Re: Cleaning the Combustion Camber Using Water?
It sounds like a picture with annotations and arrows would be perfect here!
Current
∙ 2004 VUE 124K
∙ 2007 ION3 112K
Past
∙ 1993 SL2 212K
∙ 1993 SC2 140K
∙ 1996 SC2 157K
∙ 1996 SC2 126K
∙ 2001 SC2, 145K
∙ 2002 L200 20K
∙ 2002 SL1 129K
David 93 SL2m is offline
Old 10-19-2005, 05:39 PM   #111
sierrap615
sierrap615's Avatar
i would but the photo section is down right now
Old 10-24-2005, 09:18 PM   #112
mjo
mjo is on a distinguished road
mjo's Avatar
Cleaning the combustion chamber with water is very important for a Saturn that burns oil. This is because the excessive carbon deposits sticking to the cylinder walls increase compression which increases the required octane. These same carbon deposits, by increasing the required octane, increase the likelyhood of engine knock and detonation.
Here's a quote from the Gasoline FAQ (http://www.faqs.org/faqs/autos/gasoline-faq/part3/):
"7.8 What is the effect of engine deposits?
A new engine may only require a fuel of 6-9 octane numbers lower than the
same engine after 25,000 km. This Octane Requirement Increase (ORI) is due to
the formation of a mixture of organic and inorganic deposits resulting from
both the fuel and the lubricant. They reach an equilibrium amount because
of flaking, however dramatic changes in driving styles can also result in
dramatic changes of the equilibrium position. When the engine starts to burn more oil, the octane requirement can increase again. ORIs up to 12 are not uncommon, depending on driving style [27,28,32,111]. The deposits produce
the ORI by several mechanisms:
- they reduce the combustion chamber volume, effectively increasing the
compression ratio.
- they also reduce thermal conductivity, thus increasing the combustion
chamber temperatures.
- they catalyse undesirable pre-flame reactions that produce end gases with low autoignition temperatures. "
Car has 2,000,000 mm and runs like new!
Add to mjo's Reputation
Rate the quality of this post and help mjo reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mjo is offline
Old 10-24-2005, 11:06 PM   #113
tgparker
tgparker's Avatar
1997 SW1
Well I tried the "Water Cure" this week-end for my 1992 SL1 SOHC Manual Trans Sedan, I also did a MMO soak as well as the Sea Foam spritz treatment... I saw tons of smoke come out of the exhaust, and horrible greasy black gook dibble out of the exhaust down and onto the asphalt...
The car does now run smoother, quieter, but for some reason the mileage isn't as good as it used to be... I used to get 38 mpg, today I averaged 33 mpg on a 175 mile trip......
I think I failed to follow up a very important and an integral part of the process... You have to change the oil right away afterwards... I simply ran out of daylight and weekend, and it's also been raining ever since... Damn rain, I'd do it now in the dark if it wasn't raining....Grrrrrrrr.
I've now been working and driving my SL1 to work and she runs nice and quiet, and I've also noticed more power, etc...but I KNOW I have to change that oil or all that horrible sludge is going to end up right back on the cylinder walls and piston rings. I think you also have to clean the EGR, IAC, and TBI right afterwards...
Now that I know how to do it, I can do it again next weekend now that I'll be better organized and better set up.
I would also include as part of the procedure using a large Hypodermic .... or tukey baster to slowly dribble the water or Sea Foam or MMO down the PCV tube...
tgparker is offline
Old 10-25-2005, 12:48 AM   #114
mjo
mjo's Avatar
You're right Tgparker, it's probably best to do this right before an oil change.
In case you haven't heard, a PCV Catch Can can help reduce carbon deposit formation in the combustion chamber.
The water decarbonization and emptying your catch can once in a while (every gas fillup) as well as regular maintenance will keep your car running smoothly.
mjo is offline
Old 10-25-2005, 07:59 AM   #115
98greenSC2
98greenSC2 is on a distinguished road
98greenSC2's Avatar
OK, I want to do this to my Eclipse. I can't spray the water through the throttle body like I did on the Saturn because the Eclipse has a MAF sensor. Should I disconnect the PCV hose and spray into that?
http://members.cardomain.com/stdmtn11
15.59 @ 87.1 quarter mile
1998 Saturn SC2 *sold* What have I done!?
Add to 98greenSC2's Reputation
Rate the quality of this post and help 98greenSC2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
98greenSC2 is offline
Old 10-27-2005, 08:11 PM   #116
mjo
mjo's Avatar
Hi 98greenSC2, here are my suggestions. You _could_ disconnect the PCV hose and slowly squirt water into the intake. However, as you probably know, there is vacuum in the intake. From my experience, the more deposits in the intake, the higher the vacuum. Because of the vacuum and the size of the hose, it's easy to pour too much into the intake. Thus, a better way would be to leave the PCV valve connected to the hose and just pull the PCV valve out of the valve cover. Now with the PCV valve still connected to the hose, you can tilt the valve up and then pour water into the end of the valve. There is flow restriction in the valve itself so you won't have to worry about pouring too much water into the PCV valve.
As aforementioned, you'll want hot distilled water for this process. Hot because you want all of the water to instantly turn into steam (melts in your mouth but not in your hands). Distilled because if there are minerals in the water they will form deposits in the engine. Have fun.
mjo is offline
Combustion Chamber jdw34 Vue Tech 6 07-23-2008 04:11 PM
water - Steam cleaning a 2.2L engine bgsneeze Ion General 5 12-02-2005 01:01 AM
combustion chamber cleaning daddio S-Series Tech 7 09-17-2004 08:52 PM
Piston/Combustion Cleaning? Applefool Miscellaneous Tech 2 09-30-2003 01:06 AM
water carbon cleaning EvilSL2 Miscellaneous Tech 4 05-16-2003 07:39 PM
