Old 04-17-2004, 06:58 PM   #41
David 93 SL2m
David 93 SL2m's Avatar
2004 VUE 2.2L
2007 ION-3 Sedan
Post
Originally posted by auxmike
David,how did you introduce the water into the throttle body?
I took my IceMan air intake system off and slowly poured the water with my right hand while revving the engine with my left hand. Admittedly some of the water was not making it into the throttle body; it was going down onto the things below and then onto the ground. I'm telling you, the engine jumped around like it was freaking out on drugs or something!
Maybe I didn't use enough water...?
Originally posted by thewretched
it again in a few weeks, just be ready to nudge that throttle a bit more
Well, it was a bit scary doing this and I probably won't try it again.
Current
∙ 2004 VUE 124K
∙ 2007 ION3 112K
Past
∙ 1993 SL2 212K
∙ 1993 SC2 140K
∙ 1996 SC2 157K
∙ 1996 SC2 126K
∙ 2001 SC2, 145K
∙ 2002 L200 20K
∙ 2002 SL1 129K
David 93 SL2m is offline
Old 04-17-2004, 07:06 PM   #42
auxmike
auxmike is on a distinguished road
auxmike's Avatar
Default
Sounds like I won't be trying it either!
If this is such a great idea,why don't all the dealers offer it as a service.
Makes you wonder.......
Add to auxmike's Reputation
Rate the quality of this post and help auxmike reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
auxmike is offline
Old 04-18-2004, 03:12 PM   #43
splat
splat is on a distinguished road
Default
Because they can sell you gas additives that they don't have to do anything about, except pour it in, and tell you come back on the next tank to "Make sure" the deposit's gone....they lose no time, and you think you're gettin' something great for your car...they walk out with 40 bucks and 3 minutes of work, as opposed to 40 bucks and less half an hour of work...I aimed a funnel in there, and just poured...got my SES light, just disconnected the batt, and i was off, driving again...it's called a a full fuel line flush or something...at the dealer
Add to splat's Reputation
Rate the quality of this post and help splat reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
splat is offline
Old 04-18-2004, 03:39 PM   #44
auxmike
auxmike's Avatar
Default
Splat,you aimed your funnel and just poured.Poured the water in,or a gas line cleaner?
auxmike is offline
Old 04-18-2004, 11:21 PM   #45
splat
Default
water...some of those fuel line flush are flammable, and therefore it is ill-advised...water does exactly what those would do, except remove water from the fuel tank...i aimed the funnel inwards (big one, so i wasn't afraid of it getting sucked in), and just kinda poured it with one hand, other one controlling the throttle...
splat is offline
Old 04-18-2004, 11:30 PM   #46
auxmike
auxmike's Avatar
Default
Does doing this mean some of the water can get fed back into the fuel line?
auxmike is offline
Old 04-19-2004, 02:23 AM   #47
splat
Default
no...all that water will be induced into your combustion chambers and changed to steam, clean some of the gunk out, and blow by and out the back...you don't have to worry about any of it going into your fuel lines...remember this wont clean your fuel injectors though...so you may want to run a bottle of techron through the vehicle too...
splat is offline
Old 04-19-2004, 09:35 PM   #48
thewretched
thewretched is on a distinguished road
thewretched's Avatar
Default
yeah, what splat said. its pretty time consuming, and it would be a bigger hassle to take your car out back with a jug of water and sit over it pouring water in.
especially since, you know, if they're in a hurry and mess up, no more engine. that wouldn't be too good.
but I see where you're coming from David. it was a bit frightening. I don't know how often ill be doing it, but I wouldn't tell anyone not to do it...
Add to thewretched's Reputation
Rate the quality of this post and help thewretched reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
thewretched is offline
Old 04-22-2004, 08:43 PM   #49
swzine
swzine is on a distinguished road
swzine's Avatar
Default
I kind of performed this procedure by accident!
I have a cold air intake in my car and was driving about 3 hours at around 80mph on the highway in very bad rain. My air filter is in a location where it gets hit with a lot of water. When I got to my destination the car stalled on me. It happened the second I got off the highway and into a gas station. When I'd crank it it produced a lot of white smoke and had some trouble starting. I just let it sit for a few minutes, thinking the engine was hot and maybe it would evaporate any water in there. I tried again a few minutes later and the car started up with no problems and never had a problem since.
At first I thought I had hydrolocked the engine. I knew I hadn't sucked up any standing water and the only water that could have made it into the engine were the small drips that the intake was able to vacuum up. I was still worried though.
From reading this post I now think that if I'm driving a long distance on highways in the rain it's smarter to rev the engine a little when I stop and let it turn any water into steam.
I have never met anyone with a CAI that had this condition, so it was probably a freak incident. It also does fine with normal city driving or even an hour/hour and a half of highway driving in the rain. Needless to say, I don't want it to happen again. I'm still trying to figure out the best way to solve it. There isn't any room under the hood of the L to route a Cold Air Intake anyone else. I'm leaning toward just disconnecting the CAI and using a filter on a short pipe under the hood if I'm ever driving long distance in the rain.
"God Bless America, and no Place Else!"
-Head of State movie
Add to swzine's Reputation
Rate the quality of this post and help swzine reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
swzine is offline
Old 09-06-2004, 01:30 AM   #50
cormor
cormor is on a distinguished road
cormor's Avatar
1997 SL1
Default
Now when you say denatured alcohol, is that like alcohol for wounds? Could you be more specific on this please? Ive noticed some problems and im probably gonna jump on this project tomarrow before work.
Add to cormor's Reputation
Rate the quality of this post and help cormor reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
cormor is offline
Old 09-06-2004, 05:30 AM   #51
M.Nguyen
M.Nguyen is on a distinguished road
M.Nguyen's Avatar
1993 SL2
Default
It's Ethyl alcohol. Sometimes found in windshield washer fluid.
http://www.antigravitygear.com/denatured_alcohol.html
Add to M.Nguyen's Reputation
Rate the quality of this post and help M.Nguyen reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
M.Nguyen is offline
Old 09-08-2004, 06:13 PM   #52
the_skin_eater
the_skin_eater is on a distinguished road
the_skin_eater's Avatar
1999 SL1
Default
this sounds like a good thing to do after cleanin the throttle body, if u do it on the car at least. get down all that crap u just cleaned.
Im not crazy, just bored...
http://www.cardomain.com/id/the_skin_eater ---Chek it out.
All my time goes to the Talon...My girlfriend is jealous. But my car is jealous that I sleep with her...
Add to the_skin_eater's Reputation
Rate the quality of this post and help the_skin_eater reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
the_skin_eater is offline
Old 09-16-2004, 11:08 AM   #53
BuzzStPoint
BuzzStPoint is on a distinguished road
BuzzStPoint's Avatar
2000 L-Series 3.0L Sedan
Default
Sounds interesting..
I will tackle this tonight.. Now will this help with sticking piston rings? I have tried the Piston ring soak with MMO, and B-12 BarryMans.
Add to BuzzStPoint's Reputation
Rate the quality of this post and help BuzzStPoint reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
BuzzStPoint is offline
Old 09-16-2004, 03:16 PM   #54
the_skin_eater
1999 SL1
Default
i did this a lil while ago...didnt really get the efdfect everyone else did...i got a lil steam, sputterin quite a bit, nothin outa the tailpipe. i can see s slight difference in the engine smoothness tho, i will prolly do it again soon. one thing of advise, wear a glove or sumptin cause holdion the TB open and having that release air off the manifold kinda suks..;.
Old 09-16-2004, 03:20 PM   #55
the_skin_eater
1999 SL1
Default
Perhaps you should drain your oil and see if the water ended up in the crankcase.Don't think you should see steam coming out the valve cover!
You are a brave soul,I give you credit for trying this,I hope it's done no harm to the internals though...
and although this was to sumone else, it still pertains. my oil did seem a lil watery, so take heed ppl
Old 09-16-2004, 06:07 PM   #56
BuzzStPoint
Default
I have a replacement tube that connects to the side of the valve cover. (DOHC) and while doing this the tub poped from the plug wire I proped it on and the steam got me right between the index and middle finger nuckle.. Hurts..
I had some good white and blue smoke comming out.. Nice round spot of carbon on the ground too.
Old 09-16-2004, 08:42 PM   #57
the_skin_eater
1999 SL1
Default
did u keep the engine stutterin the whole time buzz?? or did u let it gurgle, get back normal, and do it again?
Old 09-16-2004, 08:59 PM   #58
BuzzStPoint
Default
Stumble the whole time. I didn't let it go down then clear out...
Old 09-17-2004, 01:12 PM   #59
the_skin_eater
1999 SL1
Default
ahh, maybe thats were i went wrong, i let it stumble, then recover, then stumble and so on....
Old 09-17-2004, 01:18 PM   #60
BuzzStPoint
Default
Can you get a 2nd person?
I had my wife help me. she sat in the car and held the gas between 2000-2500 RPMS.
Once you get the water at a good rate and the 2nd person keep the throttle between that. you'll start to see the bugs flying around start to clear out from the smoke and steam.
Combustion Chamber jdw34 Vue Tech 6 07-23-2008 04:11 PM
water - Steam cleaning a 2.2L engine bgsneeze Ion General 5 12-02-2005 01:01 AM
combustion chamber cleaning daddio S-Series Tech 7 09-17-2004 08:52 PM
Piston/Combustion Cleaning? Applefool Miscellaneous Tech 2 09-30-2003 01:06 AM
water carbon cleaning EvilSL2 Miscellaneous Tech 4 05-16-2003 07:39 PM
