Old 10-09-2019, 05:33 PM   #1
JamesO84
JamesO84 is on a distinguished road
Default Front end roaring and vibrations
I just bought a 2000 s serious and a few days ago the driver side started vibrating sound and like a roaring noise from the tires anywhere from 35 mph up. I thought about the wheel bearing but someone said it could be a control arm. How would I tell which one it is since I cant afford to fix both. Also when I put the tire back on after changing it, and went to tighten th he lug nut up after letting the jack down there were movement in the whole tire
Add to JamesO84's Reputation
Rate the quality of this post and help JamesO84 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
JamesO84 is offline   Reply With Quote
Old 10-09-2019, 05:52 PM   #2
onlinebiker
Default Re: Front end roaring and vibrations
Jack up that wheel.
If you can rock the wheel - top and bottom - and feel/ see movement - and probably hear clunking as well - it's a bearing.
Of course if it IS the control arm - when you pop the ball joint loose from the steering knuckle - you will find that loose.
So you will find it either way. Just wait to buy parts till you determine what is defective.
How are you set for tools?
92 SC2
93 SC2
96 SC2
97 SL2
97 SC2
99 SC2
01 SC2
02 SC2
02 SL2
parts
2 94 SC2 parted out
2 96 SC2
Front End Vibrations thewayiseeit240 S-Series General 11 09-12-2012 04:57 PM
07 Vue FWD V6- Vibrations from front passenger area gpayer Vue General 4 02-08-2012 04:41 PM
Roaring sound at idle in engine bay, front passenger side... I'm thinking... wscreate S-Series Tech 9 02-08-2012 02:04 PM
roaring noise in the front end midnighttuner S-Series Tech 3 12-13-2009 11:25 PM
Vibrations from front of car saturnrings S-Series Tech 4 05-04-2002 12:06 AM
