Old 10-09-2019, 03:00 PM   #1
Eiron
Eiron will become famous soon enoughEiron will become famous soon enough
Eiron's Avatar
1999 SW2
Default Fixing worn wiper arm?
Anyone had luck repairing the splines inside the wiper arm?
Mine are worn smooth so that the spindle turns but the entire arm just rests stationary against the windshield.
He's dead Jim!
You grab his tricorder, I'll get his wallet.
Add to Eiron's Reputation
Rate the quality of this post and help Eiron reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Eiron is offline   Reply With Quote
Old 10-09-2019, 03:26 PM   #2
toggenburg
toggenburg's Avatar
Default Re: Fixing worn wiper arm?
Others have tried wrapping HD tape on the drive spindle to give it some more bite when there were still some grooves remaining inside the arm, but if they are all chewed smooth, all you can do is obtain an arm from a salvage yard.
I had to do this on a Dakota I once owned.
Old 10-09-2019, 04:43 PM   #3
onlinebiker
If the splines are reasonably good on the shaft - simply get a used arm at a junkyard.
If the splines are shot on the shaft - you could always drill through it (assembled with arm timed properly) and insert a split roll pin. You can' t hurt it if it's already broke...
92 SC2
93 SC2
96 SC2
97 SL2
97 SC2
99 SC2
01 SC2
02 SC2
02 SL2
parts
2 94 SC2 parted out
2 96 SC2
Old 10-09-2019, 07:34 PM   #4
Waiex191
Waiex191's Avatar
A Richpin classic:
https://youtu.be/2Fb6nUxBIdE
Not that old but they are all classics.
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Add to Waiex191's Reputation
Old 10-09-2019, 07:51 PM   #5
Go to JY or eBay and get a pair of good ones, they have been reproduced so you can find new. Measure your arm length and get the correct length. The install process cuts the splines into the arm and incorrect install just eats the arm.
Key worn out DonP S-Series General 8 02-20-2011 06:23 PM
worn key coolcat2 S-Series General 6 02-02-2010 03:43 PM
worn outer tie rod John Head S-Series Tech 13 12-31-2008 01:36 AM
Wiper blades worn already logbite Outlook General 12 12-04-2007 06:22 PM
worn out key Xanadu S-Series Tech 5 07-04-2006 11:17 PM
